587,322 active members*
3,104 visitors online*
Page 11 of 11 91011
Results 201 to 208 of 208
  1. #201
    Aug 2010
    127
    Quote Originally Posted by Fastest1 View Post
    I use a granite floor tile to tram. They are ground with extremely accurate machines. Any deviation would show as a defect. They are cheap at a flooring store. They allow you to do a 360 degree sweep of 12". I can not tell any difference in thickness when measuring it on my granite surface plate. Great tool and inexpensive. Good to place sandpaper on to make an item flat too.
    Great advice! I did pick up some scrap granite at our industrial center of town a great price. I'm sure this piece will prove invaluable down the road.
  2. #202
    Aug 2010
    127
    Well I finally am back on my two feet walking again and got back to work on the mill. I bought another rod other than the cheap drill rod I was using and things went much smoother. I was able to tram the head to the column side to side in about an hour which probably isn't too bad for my first time. Its actually not as bad as I thought
    I ordered up a tsunami bilge pump, threw it inside a pond filter and that inside of a 5 gallon bucket for flood coolant. Everything is wired up and ready to go! I built an enclosure that drains off to one side.
    Out of curiousity, and this might sound like a dumb question, but if I wanted to throw a Nordic Track or BF30 motor on my mill will I need to make new motor mounts?
  3. #203
    Nov 2009
    4415
    Yes and wait til you have the motor in you hand as they are different diameters. Mrcodewiz has the mount for the 3.8 Proform, you would need a KBIC or similar to control it too.
    A lazy man does it twice.
  4. #204
    Aug 2010
    127
    Gotcha! I haven't ordered a motor up, but they seem cheap on ebay and would be a fun project.
  5. #205
    Aug 2010
    127
    Since I've had so much time to just sit lately, I've been wondering if there are steps I've missed during the setup or conversion process. One topic that I've seen is preloading A/C bearings. I do have A/C bearings on all three axes. What is the normal method to preload these bearings?
  6. #206
    Aug 2010
    127
    I was measuring the tram in my earlier posts.
  7. #207
    Jun 2011
    Glad to read your foot is back to normal, have you any pics of your flood enclosure and bilge pump....I've reverted back to my 12VDC original bilge pump too, and as you have your axis wired you could simply draw and machine a new motor mount plate for what ever motor you decide to use...
    Eoin
  8. #208
    Aug 2010
    127
    I will try and snap a few. The enclosure is just epoxy painted plywood sealed with RTV. The pump itself sits in a pond filter with the 1/4" line come out for the coolant nozzles, and that assembly inside of a home depot bucket.
    Nothing all that remarkably fancy. I've been seeing what some members are able to do with some 80/20 and corrugated plastic. I plan on getting a Gorilla workbench and building an 80/20 assembly around it at some point.
    I'm keeping my eyes out for a stronger motor. Is 2-2.5hp about the right range? I also have a friend that welds and am thinking about having him weld up some steel plates to bolt the column to the base for some rigidity.
Page 11 of 11 91011
  1. My G0704 CNC conversion adventure
    By Xnaron in forum Benchtop Machines
    Last Post: 12-15-2013, 05:47 PM
  2. upgrading from g0704 conversion
    By dsdmax in forum Charter Oak Automation Support Forum
    Last Post: 12-01-2011, 11:39 PM
  3. G0704 Conversion
    By rcazwillis in forum Benchtop Machines
    Last Post: 07-17-2011, 03:27 PM
  4. My Grizzly G0704 Conversion to CNC
    By DrewSmith007 in forum Benchtop Machines
    Last Post: 04-11-2011, 05:42 AM
  5. g0704 - conversion project
    By dsdmax in forum Benchtop Machines
    Last Post: 03-02-2011, 04:03 AM
