supply with CE certificate.
1.The machine adopts imported linear square and 4 lines double slider.Larege loading capacity,run stably,high precision,long life, accurate cutting.
2.The whole machine use seamless steel,bettter rigidity,working table backing steel plate,rigid strength and loading capacity of the machine can be more than 1000 KG.
3.Constant power spindle motor,powerful cutting intensty, high effeciency.
4.Good compatibility for CAD/CMD software,including Type 3,Artcam,Castmate,Artgrave etc.
5.The cooling system for tools improves its life.
Applicable materials:
Granite, marble, bluestone, sandstone, thin soft metal etc stone engraving
Density stone such as granite can be engraved to 3mm repeatedly
Some stone such as marble, bluestone can be engraved to 3mm at one time.
Specification:
1)X Y axis working area:1,300x3,500mm
2)Z axis working area:300mm
3)Table size:2,000x4,000mm
4)Max.speed:0-10,000mm/min
5)Max.working speed:0-3,000mm/min
6)Working delicacy:0.02mm
7)Reposition accuracy:0.05mm
8)Max.feeding height:300mm
9)Engraving Command:G code,u00,mmg,plt
10)Software:Type3,Artcam,Ncstudio software
11)Max.powerconsumption:6 KW
12)Spindle:1.5KW/2.2KW/3KW/4.5KW/HSD 1.5KW/HSD 3KW/HSD 4.5KW/HSD5.5KW/HSD 6KW/HSD 7KW variable speed, water cooled /air cooled
13)Spindle speed:18000/24,000rpm
14)Work type:stepper
15)Weight:1200kg
16)Working voltage AC380V,50/60Hz
17)Memory:32M
18)Manner of receiving data:USB orPCI
19)Running circumstance temperature: 0 - 45°C
20)Relative humidity: 30% - 75%
Jinan G.Weike Science & Technology Co.,Ltd.
Laser engraving machine|Laser cutting machine|CNC router-G.Weike Laser
Tel:+86-0531-88020976
Mobile:8615154147619
Fax:+86-0531-88912386
Email:[email protected]
