587,201 active members*
2,849 visitors online*
Results 1 to 18 of 18
    Jul 2011
    26
    CNC4PC C11 Card and Huanyang VFD
    I recently decided to upgrade to a bigger spindle motor with a VFD (HUANYANG), controlled by a cnc4pc c11 card. After a steep learning curve and some other issues I finally got the VFD set and the elusive +10V analog output out of the c11 to control the motor speed. As far as I can see, when I increased/decrease the spindle speed in Mach3, I can measure the voltage going up and down, as well as the frequency in the VFD, but the motor does no turn.
    I can operate the motor manually using the VFD panel, but when I try to operate it remotely with the analog input, it doesn't. I know that there's got to be a PD setting that needs to be changed, but I cannot figure it out. Anyone...please!
    Jul 2011
    26
    I've seen that quite a few people have read my post...please I need help...I am dead in the water!
    Thanks,
    May 2004
    162
    VFD
    Quote Originally Posted by Lasr Da Vinci View Post
    Thanks,
    On the VFD's I've worked on, there is a Start/stop set of terminals and a Safeties set of terminals. These must be activated. Start/stop from a relay contact and just short together the Safeties.
    Hope that this helps.
    Jun 2007
    3734
    Please post your wiring diagram and some pictures.
    We need more information to help you.
    Also the Mach3 spindle settings you have used.
    Apr 2005
    1268
    Did you make the reqired settign on the VFD for remote operation? If yes, are you getting the voltage signals on the VFD (at the terminals). Do you have the wires connected to AV (hot) and ACM (common). That was my last problem, I had miswired the common signal.
    This is all from memory so check your VFD manual for the correct terminal numbers on the voltage input.
    Good luck.
    Bill
    billyjack
    Helicopter def. = Bunch of spare parts flying in close formation! USAF 1974 ;>)
    Jul 2011
    26
    The VFD works fine manually, either using the keypad or potentiometer (by changing the jumper settings from 1-2 to 2-3 and viceversa)
    Mach 3 is setup according to the C11 card instructions. the +10V analog voltage output goes up and down according to the M3 S value (S24000= +10V, S12000= +5V).
    When these output signal is connected to the VFD input ACM (negative) and VI (positive), I can see the frequency on the VFD display changing from F400.00 when the spindle is set to S24000 on Mach3, and it goes down as I lower it on Mach3. That's why I think that I am missing some simple setting on the VFD.
    As far as I know, the VFD settings for remote operation are:
    Jumpers: pins 1-2 shorted (VI)
    PD001 is set to 1
    PD002 is set to 1
    PD070 is set to 0
    PD071 is set to 20
    PD072 is set to 400hz
    PD073 is set to 0hz
    Jul 2011
    26
    P38nut,
    Do you have an schematic for shorting the safeties you mention?
    Thanks,
    Gustavo
    Jun 2007
    3734
    Divide the problem.
    Get a pot and put speed signal direct into the VFD using the diagram in the VFD manual.
    And put a few switches as per the diagram.
    Then confirm all the VFD settings, and write them down.
    Is the VFD new? If not restore all the factory defaults. Who knows what was setup in it.
    You must select external operation using settings in the VFD manual to get any senses out of external wiring.
    Once you can operate it remotely, then hook up the C11 (awful thing it is).
    You will need to change a few settings in the VFD to get the Mach3 speed to match what the VFD is doing.
    It would appear that you have the speed signal OK, but the stop/start/reverse pins not doing what is intended.
    Apr 2005
    1268
    Yup, another thing I forgot to mention. You must also jumper (or use a relay) for the +10 volts on the forward or reverse pin. I doin't have a manual handy but there should be a for and rev pin that needs the +10 from the inverter to operate. Let me know if you can't find the correct pins and I'll download another manual and confirm that I'm just not getting senile!
    Bill
    billyjack
    Jul 2011
    26
    Quote Originally Posted by bill south View Post
    Bill
    I think that this is the step that I am missing.
    I am looking at the wiring terminal diagram, and I see the FOR & REV terminals. Are these the ones that need to be jumped for the +10V? Could you please tell me how to do this? I am a newbie, and I'm learning as I go!
    Attached Files Attached Files
    Apr 2005
    1268
    If you are not using spindle direction control via the C11 card, then just jump +10 to the foward terminal. If you are using the relays for direction control, connect the +10v to the common terminal on the C11 card (common for the relays not power common) and connect the forward/reverse terminals of the C11 card respectively. Don't forget to set up Mach as directed in the C11 manual. Hope this works for you!
    Bill
    billyjack
    May 2004
    162
    wiring drawing
    P38nut,
    Thanks,
    Gustavo
    Take a look at this for your testing purposes.
    Jul 2011
    26
    Thank you P38nut for the schematic. I have the vfd manual and I am familiar with that schematic. My +10v is connected to the VI terminal and the negative to the ACM. As per Bill's previous message, it appears that I need to bridge the FOR terminal with the +10v, and I think that that's exactly what I didn't do. I'll give it a try tonight and see what happens.
    Dec 2003
    24223
    From my experience the +10 volts is nothing to do with the FOR REV terminals, this is for the analogue input speed control, the FOR/REV inputs are just sunk OR contact closure to DCM (common).
    Closing either of these will run the motor at the rate set by the pot or analogue input.
    ACM is the analogue common.
    Al.
    Albert E.
    Jul 2011
    26
    We got Lift off! I finally got it to work. Jumping FOR and DCM allows me to control speed using the +10V analog input from the C11 card. Thank you very much.
    Apr 2009
    220
    Hi, I am now in the same position you were. I cannot figure out where to connect the 10V output and relays from C11.
    Could you please provide the schematic with which you managed to make it work?
    Thanks.
    Apr 2009
    220
    Please provide a schematic
    Thanks.
    Jul 2011
    26
    PM Sent.
  1. Replies: 2
    Last Post: 02-24-2011, 08:20 PM
  2. CNC4PC C6 spindle control card and EMC
    By DanC in forum LinuxCNC (formerly EMC2)
    Last Post: 11-28-2010, 06:42 PM
  3. cnc4pc C6 card and vdf
    By hudmut in forum Benchtop Machines
    Last Post: 10-02-2009, 03:47 PM
  4. CNC4PC C3 Index Pulse Card - Help
    By TravisR100 in forum CNC Machine Related Electronics
    Last Post: 06-30-2009, 01:50 AM
