587,158 active members*
3,189 visitors online*
Page 1 of 2 12
Results 1 to 20 of 34
    6855
    Sloppy printing start
    How do I fix the problem of my printing starts over ejecting plastic? Is their a setting to change the time the printer head starts to eject plastic and starts to traverse? I'm using the ini config and .5mm tip.
    Sep 2012
    1543
    Tell it .4mm tip, and make your retraction more, what software are you using, I have a slicer config file I could send you tonight for your exact printer. Pictures help describe your problem better too.
    6855
    The file would be great
    Nov 2012
    Quote Originally Posted by CNCadmin View Post
    Hi CNCadmin,
    Have you tried the point5mm.ini file found here? Index of /AO-100/software/2012-Q2/configs/slic3r
    You can also try the .ini files for slic3r found here
    Index of /AO-101/software/current/slic3r/config
    Filament Retraction should be set to 1.4mm - 1.6mm depending on how fast you are printing.
    If you have any questions or comments, please feel free to ask.
    Best Regards,
    Jon Fye
    Sales Associate
    [email protected]
    1-970-377-1111 x633
    Aleph Objects, Inc.
    123 SW 12th Street
    Loveland, Colorado 80537
    United States of America
    Aug 2008
    187
    better be careful, you all banned bamcnc when he was b_rad, you might get something you don't want.
    6855
    Quote Originally Posted by Jonlulz View Post
    Hi CNCadmin,
    Best Regards,
    Jon Fye
    Sales Associate
    [email protected]
    1-970-377-1111 x633
    Aleph Objects, Inc.
    123 SW 12th Street
    Yes that is what I'm using, I will post a pic of what I'm getting.
    Nov 2012
    Hi CNCadmin,
    ok I will wait for the picture(s)
    Best Regards,
    Jon Fye
    Sales Associate
    [email protected]
    1-970-377-1111 x633
    Aleph Objects, Inc.
    123 SW 12th Street
    6855
ID:	172874 here is a pic
    Nov 2012
    Hi CNCadmin,
    Are you printing just one object at a time? Also, what speed are you printing at? If you are printing jsut one object on the heatbed at a time you might try adding another object to the print job to allow more time for each layer to cool before the next layer is applied.
    Best Regards,
    Jon Fye
    Sales Associate
    [email protected]
    1-970-377-1111 x633
    Aleph Objects, Inc.
    123 SW 12th Street
    6855
    I was just printing one. I'm using the stock settings.
    Dec 2012
    Quote Originally Posted by bjones View Post
    I concur.
    Dec 2012
    Quote Originally Posted by BAMCNC.COM View Post
    Don't do this. I also do not believe this person has this printer.
    Dec 2012
    Which stock settings, ours or the stock ones in Slic3r itself? Also which version of slic3r? If you could point at the URL of the .ini you are using, that would be nice.
    Jon actually pointed at two different stock settings. The one for 0.8.4 (the top URL) and 0.9.7 (the bottom URL, which is the latest slic3r version). I would suggest using the latest/greatest release of slic3r and this config, just to be clear:
    http://download.lulzbot.com/AO-101/s...zl_pt4-lyr.ini
    It basically looks like it is extruding too much material. You can adjust this by lowering the extrusion multiplier (Filament Settings-->Filament). You shouldn't have to adjust this though--there may be something else up with the settings (e.g. you have Slic3r's defaults, not ours, for instance).
    Also, feel free to paste your .ini somewhere and we can take a look at it.
    If the part is really small (which it kind of looks like), it can also be helpful to print multiple copies on the same plate. This allows it to cool down more between layers.
    Thanks,
    -Jeff
    6855
    I have a AO-101 not the 101
    acceleration = 0
    bed_size = 200,200
    bed_temperature = 0
    bottom_layer_speed_ratio = 0.75
    bridge_fan_speed = 100
    bridge_flow_ratio = 1
    bridge_speed = 40
    complete_objects = 0
    cooling =
    disable_fan_first_layers = 1
    duplicate = 1
    duplicate_distance = 5
    duplicate_grid = 1,1
    end_gcode = M140 S60 ; turn down bed\nG1 X0 ; home X axis\nM18 ; disable motors
    extruder_clearance_height = 20
    extruder_clearance_radius = 20
    extrusion_axis = E
    extrusion_multiplier = 1
    extrusion_width_ratio =
    fan_always_on = 0
    fan_below_layer_time = 60
    filament_diameter = 2.89
    fill_angle = 35
    fill_density = 0.75
    fill_pattern = line
    first_layer_bed_temperature = 0
    first_layer_height_ratio = 1
    first_layer_temperature = 0
    g0 = 0
    gcode_arcs = 0
    gcode_comments = 0
    gcode_flavor = reprap
    infill_acceleration = 50
    infill_every_layers = 1
    infill_speed = 90
    layer_gcode =
    layer_height = 0.25
    max_fan_speed = 100
    min_fan_speed = 35
    min_print_speed = 10
    notes =
    nozzle_diameter = 0.5
    output_filename_format = [input_filename_base].gcode
    perimeter_acceleration = 25
    perimeter_speed = 60
    perimeters = 2
    post_process =
    print_center = 85,80
    randomize_start = 1
    retract_before_travel = 1
    retract_length = 1.4
    retract_lift = 0
    retract_restart_extra = 0
    retract_speed = 25
    rotate = 0
    scale = 1
    skirt_distance = 6
    skirt_height = 1
    skirts = 2
    slowdown_below_layer_time = 20
    small_perimeter_speed = 60
    solid_fill_pattern = rectilinear
    solid_infill_speed = 90
    solid_layers = 3
    start_gcode = G28 ; home all axes
    support_material = 0
    support_material_tool = 0
    temperature = 0
    threads = 2
    travel_speed = 150
    use_relative_e_distances = 0
    z_offset = 0
    6855
    Dec 2012
    No fan needed.
    -Jeff
    Dec 2012
    It appears you are using the config for the 0.8.4. This is ok, but slic3r has had vast improvements since then. I suggest using the latest 0.9.7 version of slic3r, freely available at slic3r.org and use this config:
    That is what shipped with the AO-101 (you have AO-100), but they can use the same slic3r config. We also have a finer resolution version of the config for 0.5mm nozzles in the same directory:
    http://download.lulzbot.com/AO-101/s...zl_pt3-lyr.ini
    I suggest giving that a test and also printing multiple parts on the same plate, which helps when printing small parts (which from the photo, it appears your part is).
    Thanks, and if you have any other questions, feel free to ask.
    -Jeff
    Sep 2012
    1543
    Quote Originally Posted by jebba View Post
    Wow, this thread turned funny.... Sorry I haven't been on this weekend to send you my config, but sounds like your getting help.... And you would be suprised what .4mm does when entered in slicer. Your right I don't have a lulzbot prusa right now, I sold it.....
    6855
    working great now!
    Aug 2008
    187
    really? why would you do that? you said you won an ebay reprap prusa mendel just a few months ago. got any pics of the lulzbot you claim to have owned? your lies are catching up to you b_rad.
Page 1 of 2 12
  1. 3D Printing Live! Joining the ranks of the international 3D printing conferences
    By cncadmin in forum 3D Printer / 3D Scanner Discussion
    Last Post: 10-15-2013, 09:20 PM
  2. Sloppy x2 z gibs
    By sabastion in forum Linear and Rotary Motion
    Last Post: 08-03-2011, 12:50 PM
  3. sloppy X2 Z gibs
    By sabastion in forum Benchtop Machines
    Last Post: 07-29-2011, 01:40 AM
  4. Sloppy Spindle
    By twocik in forum Tormach Personal CNC Mill
    Last Post: 03-04-2011, 06:59 AM
  5. Sloppy Geometry - PLEASE HELP!!
    By NardisAmps in forum OneCNC
    Last Post: 05-19-2008, 08:39 AM
