587,143 active members*
3,603 visitors online*
Results 1 to 6 of 6
    Jan 2012
    Step jog doesn't work
    Mach 3 and mill work great for everything except for step jogging. When I first set up everything, the step jogging worked, but it does not work now. Manual jogging works just fine all the time, but no step jogging on any axis in any direction for any amount of movement. I do my jogging with the Mach3 screen using the "Tab" key and all screen sets are stock.
    I don't think I have changed anything in my configuration that should affect step jogging, but I must have done something. Any suggestions will be greatly appreciated.
    rkbuild
    HF X2 Mill, HF 7x14 Lathe; Working on the CNC some day
    Sep 2012
    1543
    In the TAB screen there should be settings to fix that, what version of mach do you have?
    Nov 2004
    436
    Check "Jog Increments in Cycle Mode" page on general config page, and make sure it is not populated with zero's.
    Jan 2012
    I have the latest full release version of Mach 3.
    rkbuild
    Jan 2012
    OK, this one falls into the gremlin group. Got home from work, started up the computer and mill control box and everything worked as it should. Did not touch a thing.
    rkbuild
    Sep 2012
    1543
    Check your grounds and shielding, do you have one point your grounds go to or multiple? You don't want a different potential between grounds.
  1. probe doesn't want to work
    By metalmansteve in forum Haas Mills
    Last Post: 06-25-2012, 10:38 PM
  2. G72.1, G72.2 doesn't work!
    By Maxz in forum G-Code Programing
    Last Post: 11-18-2011, 05:16 PM
  3. Stepper Doesn't work, what to do ???
    By twocik in forum Benchtop Machines
    Last Post: 04-27-2008, 08:15 PM
  4. The keyboard doesn't work
    By TU ANH DUNG in forum Fanuc
    Last Post: 07-23-2007, 06:32 AM
  5. Replies: 0
    Last Post: 08-26-2005, 07:22 PM
