587,236 active members*
3,662 visitors online*
Results 1 to 6 of 6
    Nov 2007
    45
    DMG HSC 75 LINEAR 5 AXIS
    Hi guys
    anyone working with or have experience with the above machine? would like to know what I'm getting into
    regards
    anilam
    Dec 2012
    Did you get the HSC? Siemens or Heidenhain Control? Late reply I know
    Nov 2011
    40
    We just got HSC 55 linear with sinumerik 840D Solutionline.
    Tomorrow we will make first chips on it i cant wait for it.
    It is fast i know that one.
    And it looks like a beauty.
    I worked on Mori Seiki 4000 DCG (4 axis) and Huron KX8Five (5 axis) but this is a beast of a machine
    Nov 2007
    45
    Quote Originally Posted by FMAX View Post
    yes we got the HSC with the Heidenhain controller - freaking awesome!!
    I must post the parametric pgm I wrote for it to mill a block square and measure it.
    Dec 2012
    That control is very powerful. You have so many options on the control for programming. I really like the FN Function programming and SL Cycles. Just hate having to put Z+195 FMAX M91 in for B axis approaches over 20degrees. I have a Engraving Macro if your doesn't have an Engraving cycle.
    Nov 2007
    45
    right here is the macro's I wrote over a year ago.
    this is specific to my application and setup which is milling PET molds out of 7075 aluminium.
    these macros measure & mill the block to size automatically. I've changed the ext to txt u can change it back to h.
    DO NOT RUN THIS ON YR MACHINE AS THE DATUM POINTS ARE OUT AND YOU WILL CRASH YR MACHINE.
    USE IT FOR REFERENCE / GUIDE ONLY.
    Attached Files Attached Files
  1. 2 axis linear slides
    By Smackre in forum Linear and Rotary Motion
    Last Post: 05-26-2010, 08:54 PM
  2. Linear Motor Axis Drives
    By AppliedMachine in forum Linear and Rotary Motion
    Last Post: 01-19-2009, 04:48 PM
  3. THK linear actuator in Z axis
    By calzages in forum FAQ of DIY CNC Machine Building
    Last Post: 11-28-2008, 07:36 PM
  4. Linear Rails for the Z Axis
    By Bird_E in forum Charter Oak Automation Support Forum
    Last Post: 08-31-2007, 07:45 PM
  5. Need some Linear Rails for Z-Axis
    By ViperTX in forum Linear and Rotary Motion
    Last Post: 09-21-2005, 04:29 AM
