588,076 active members*
4,887 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > can i build cnc using brushless dc motor?
Results 1 to 9 of 9
    Dec 2005
    6
    i have burshless dcmotor with encoder .can i use it for building cnc?
    if i can how can i use encoder ?
    May 2005
    18
    Brushless dc servo?
    I have the same question.
    I have the motors and would sure like to find a controller so I could use my “brushless” DC motors.
    Thanks,
    Doug
    Nov 2004
    30
    Both Rutex www.rutex.com and gecko www.geckodrive.com have controller for brushless motor. The encoders will connect to the controller and drive the motors as instructed by the control software such as mach 3 (www.artofcnc.ca)
    35538
    Gecko does NOT make a brushless drive.
    May 2005
    18
    Brushless servos
    Inventthis,
    I talked to Gecko and he said he did NOT have a controller for BRUSHLESS servo motors.
    My main question is..Why are Brushless servos so "unusual'
    I will check out the other site.
    Thanks,
    Doug
    746
    In the world of big machines, the motor trend has gone to the use of brushless servo motors thanks to digital electronics. They are basically a small 3 phase motor driven by a fancy VFD with feedback.
    If it's not nailed down, it's mine.
    If I can pry it loose, it's not nailed down.
    May 2005
    18
    Talking
    2muchstuff,
    The servos I have are very expensive if bought new..like $1200.00 each.
    I did not pay that for them. Are they good for anything?
    I don’t want to spend $200.00 per axis ( X4).
    They came on some linier motion tables I found.
    BTW the tables weigh 40 lbs each, they are SS and I believe to be dead on with NO detectable backlash they only have about 6” of travel, but I have 4 of them and I am going to put together a cnc mill.
    What size steppers would work well for these tables? Stepper/controller combo?
    Thanks,
    Doug
    P.S. I just today finished my 3 phase Rotory coverter.
    20 hp idler motor, start with 1/2 hp poney motor...runs like a TOP.
    Maybe I could use this 3 phase to run these servos..Just kidding.
    746
    I know where there are 3- AC brushless drives collecting dust. Can be gotten very cheap I would bet.
    May 2005
    18
    Smile
    Quote Originally Posted by 2muchstuff
    Now you can add 4 dc brushless servos to that list.
