588,183 active members*
4,287 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > 8 wire Stepper motor wiring connection
Results 1 to 9 of 9
    Apr 2004
    I'm having problems finding the wiring diagram for
    Slo-Syn 8 wire stepping motors. The part number on
    the motor is M063-Le-507e. The label on the motor also specifies this: connect per 225373. Does anyone have any
    wiring diagrams for these motors?
    Jun 2004
    38
    Hi hornet, hope this helps.
    Attached Files Attached Files
    Jun 2004
    38
    This is a better, more informative one.
    http://www.slosyn.com/manuals/SS2000MD7.pdf
    Apr 2004
    Thanks for your help.... GrahamIT. I was wandering if you would know how to cross-reference my
    wiring harness though.... I have these colored wires... Red, Brown, Yellow, Orange, White/brown,
    White/red, White/yellow, White/orange, and chasis ground green.
    Jun 2004
    38
    Sounds like you'll have to set to with an AVO meter and find out which pair of wires join to which coil, sorry I couldn't be more helpful.
    Mar 2006
    Does anyone know how to connenct a SLO-SYN M063-CS09 ?
    It has a 8 pin connector
    Oct 2004
    742
    Quote Originally Posted by hornet
    WINDING COLOR CODE:
    Winding 1 Yellow and white/yellow
    Winding 2 Red and white/red
    Winding 3 Brown and white/brown
    Winding 4 Orange and white/orange
    Wiring in Series:
    Yellow A Phase
    Red B Phase
    Brown C Phase
    Orange D Phase
    white/yellow connects to white/red
    white/brown connects to white/orange
    Parallel:
    Yellow connected to Red (A)
    white/yellow connected to white/red (B)
    Brown connected to Orange (C)
    white/brown connected to white/orange (D)
    GREEN IS CHASSIS GROUND CONNECTION.
    Hope this helps.
    Jerry
    Oct 2009
    3
    Hi i have an 8 wire portescap disc magnet stepper motor and i dont know how to wire it and what to wire it too. Could you help please.
    Sep 2011
    IDENTIFY LEADS ON A 8 WIRE STEPPER MOTOR
    I figured out this method to identify any 8 wire motor. Hope it helps.
    You will need an bi-polar driver that is set to spinning to work.
    Identify leads on a 8 wire stepper motor « Dreamation Workshop
  1. Using Cat 5 cable for stepper motors?
    By 10bulls in forum CNC Machine Related Electronics
    Last Post: 04-24-2005, 04:24 AM
  2. 12 wire stepper
    By extreme in forum Stepper Motors / Drives
    Last Post: 03-25-2005, 12:56 AM
  3. How to Wire the Camtronics Stepper motors?
    By Cold Fusion in forum CNC Machine Related Electronics
    Last Post: 05-27-2004, 08:15 PM
  4. Correct Stepper Wire ? ?
    By Mr.Chips in forum Xylotex
    Last Post: 05-08-2004, 02:44 PM
  5. 10 wire stepper
    By xairflyer in forum DIY CNC Router Table Machines
    Last Post: 01-08-2004, 09:19 PM
