587,173 active members*
4,003 visitors online*
IndustryArena Forum > Material Technology > Material Machining Solutions > Machining an Epoxy Resin Table Top
Results 1 to 2 of 2
    Feb 2009
    237
    Hi Group!
    Let me make the story as short as possible. Some time ago I went to an auction place and saw this awesome black top table for a ridiculous price, so needless to say I picked it up in a flash thinking I was getting a humongous delrin slab. Errr! Big Mistake! Apparently, what I got is actually an Epoxy Resin Table Top as those found on laboratory tables.
    So my question is: Can I still (or better said should I even bother with) machine this material? I read somewhere that to cut it I would need diamond blades and diamond drill bits. I feel the table top is kind of hard, but not that hard. Of course, I am completely oblivious as to what would it take to machine this material.
    I would have made an experiment but if it is not worthwhile, I plan on selling the table as it is. Hence, it doesn't make sense to butcher it with a carbide wheel if at the end there is nothing I can do with it.
    Thanks for your input!
    May 2007
    95
    Re: Machining an Epoxy Resin Table Top
    As I understand it, the issue would be if the material is a composite of epoxy and granite, sand, or other rocks and minerals. If so, then you would need the diamond tooling to cut through those materials as the tool passes through the epoxy. However, if the table were really just solid epoxy, you probably wouldn't have any issues.
  1. PU Polyurethane resin / Epoxy alternative
    By yellow_submarin in forum Epoxy Granite
    Last Post: 07-23-2012, 10:06 PM
  2. choosing the correct epoxy resin
    By jerrywi in forum Momus Design CNC plans
    Last Post: 04-07-2012, 02:23 PM
  3. Epoxy resin and Silicone Rubber mold help
    By Ikaros in forum Moldmaking
    Last Post: 08-23-2011, 12:18 PM
  4. Self leveling epoxy resin-wear characteristics?
    By Splint in forum Uncategorised MetalWorking Machines
    Last Post: 07-23-2007, 02:11 PM
  5. Epoxy resin floor paint and MDF.
    By Oldmanandhistoy in forum DIY CNC Router Table Machines
    Last Post: 02-25-2006, 09:09 PM
