587,567 active members*
3,742 visitors online*
IndustryArena Forum > CAM Software > SheetCam > THC 300 Problem
Page 1 of 2 12
Results 1 to 20 of 23
    Jul 2011
    THC 300 Problem
    I am new to this forum. Need some help, I am running a plasma table, running sheet cam 3.0.16 and mach 3. Things run pretty good, using Mach 3 plasma post processor. I recently added a floating head and when I switched to the THC 300 post processor I am getting a stop and go or jerky motion on smaller curves. I put in a file with some small text (approx 1/2 inch high) and with the MACH 3 processor it seems to run pretty good but as soon as I switch to the THC 300 processor the problem starts.
    Do you have any suggestions as to what the problem is?
    Jun 2010
    178
    Sounds like the other post processor is putting Mach3 into exact path mode. Can you copy and paste the preamble from the top of the jerky G-Code here?
    If you see a G61 (exact stop mode) replace it with G64 P0.005 The P variable sets the tollerance, the higher the number the closer to the commanded velocity your machine will stay at the sacrifice of accuracy.
    Jun 2010
    178
    Can you post the top section of both outputted GCodes please. I just tested both on my computer and both pieces of GCode look essentially identical. The arcs are both handled the same and neither of them seems to specify exact path or constant velocity mode.
    Jun 2010
    178
    Try putting G64 P0.005 at the top of your gcode, run it, get back if the problem persists.
    Also since you built your machine what are your max acceleration values? Are they consistent over each axis?
    Jul 2011
    Quote Originally Posted by lukewarm View Post
    Thanks for the help. I don't see a G61 and am not sure how or where to place the G64 P0.005, do I need (post in front of it). not familiar with coding.
    Not sure which section G code starts. I played with acceleration and velocity with the Mach 3 plasma post seems to work pretty good. Velocity 231 acceleration 31 have turned velocity down to 130 and acceleration to 18 with not much change. Will try to post the G code you asked for soon.
    Thanks again.
    Jun 2010
    178
    Just add it to the top of your gcode file!
    Jul 2011
    I have attached the screen shot for the jerky G-code. I tried putting in the G64 P0.005 with no success, providing I put it in the right place.
    Jul 2011
    Quote Originally Posted by 34chev View Post
    Here is the screen shot. Sorry never showed in last reply.
    Attached Files Attached Files
    Jun 2010
    178
    Alright I attached the file with the G64 command where it should be. Can you re-run it with the G64 in that position and tell me how it goes?
    Also you never attached your non-jerky Gcode. Can you at least give me a line count for each file? If one file is substantially longer this means one post processor is not joining similar arcs together. I doubt this is the issue, however.
    I notice you are in Canada, I'm also in Canada (BC) if you feel like PMing me contact info I can call you and walk you through some troubleshooting over the phone if you like.
    Jul 2011
    There is no attachment.
    But the line count is MACH3 Plasma 31930
    THC300 32530
    Jun 2010
    178
    You're right I must have forgot to attach it. Anyway put it after g53 at the top of the file. But after gauging by your for length I don't think you are combining short line segments. Can you upload the model file?
    Jul 2011
    Here is the whole file. Inserted the G64 made no difference.
    Jun 2008
    562
    Here is the post I use on my Orphan DynaCnc with floating head plasma based on the Caudle post. Set the switch offset to match your machine and give it a try. They look very similar.
    After you load the Gcode in Mach go to the config page and make sure "exact stop" is not specified, it should be "constant Velocity".
    Good Luck
    Mike
    Jul 2011
    Quote Originally Posted by Mike 1948 View Post
    Good Luck
    Mike
    Installed it, tried it and no change , Thanks for the help.
    Jun 2010
    178
    Chevy can you post the original dxf file you made the gcode from. I'm pretty sure I can fix your problem
    Jul 2011
    Here it is.
    Jun 2010
    178
    Chevy have you tuned your CV yet?
    Check out this link, I still think it's a CV issue.
    http://www.machsupport.com/docs/Mach3_CVSettings_v2.pdf
    Jul 2011
    I have tried setting the motor acceleration and velocity, there was no change. I have checked the other CV settings will check again tomorrow. Will increase look ahead mine is set pretty low.
    Thanks again
    Jun 2010
    178
    Try using G64 P0.05 instead of P0.005 and see if it improves any.
    Jun 2010
    178
    If still no change change it to P0.5 and check for a difference. Note that your cuts will be horrendous but it will let us know that your accelerations are too low to maintain a constant feed rate and give us a few options. One of which being increasing your acceleration rate (if possible) or using a lower amperage consumable to decrease your feed rate.
Page 1 of 2 12
  1. Tube problem or powersupply problem? Help you to check out
    By Melody-gweike in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-05-2012, 04:09 AM
  2. daewoo puma 12lb tape format problem/parameter problem
    By robb12877 in forum Daewoo/Doosan
    Last Post: 08-25-2011, 06:13 AM
  3. Replies: 5
    Last Post: 08-04-2010, 11:33 PM
  4. machine problem or software problem?
    By bcnc in forum Syil Products
    Last Post: 10-26-2009, 03:51 PM
