Hi Robin,
Soldering is fine but remember the electrodes are tungsten so won't solder properly, you also risk heat cracking the support. I use a dedicated clip that came fitted on my machine but I have seen others use "chocolate blok" type connectors very successfully. Just remember, not too much strain a good shield made from 4mm wall silicon hose is all you really need to insulate the terminal.
best wishes
Dave
