587,832 active members*
3,276 visitors online*
Results 1 to 6 of 6
    Mar 2013
    Biesse Rover A3 - PLC error
    Hello,
    I have two strange errors on my Rover A3 when I start up machine.
    It says:
    PLC 375 > Time-out during communication with a device ax.0
    PLC 372 > HALT
    http://www.abload.de/img/errordlko6.jpg
    After that, I can't power on Rover, I should get signal (RED light ON) but nothing.
    What kind of problem is this?
    Is something serious or not?
    How to get rid of that error?
    Thnx a lot.
    Nov 2009
    314
    Hi ,
    Time-out during communication often occurs whenever the driver isn't installed well ,so no communication with PC and Machine . You may have a check ~ Well we are not familiar with this controller system . Have you consult with the manufacture and get help from the technician .
    Best regards,
    XYZ Machinery
    Feb 2009
    15
    you have a problem with the PLC its in HALT. try to send your log file to Biesse, they can tell you where is the fault
    Feb 2018
    Re: Biesse Rover A3 - PLC error
    Hi
    i have the same problem and i get just like your errors did you solve that?
    Apr 2019
    13
    Check the connections on the back of the PC.
    This is generally a problem with the connection between the PC and the machine.
    Could also be the network card in the PC.
    Quote Originally Posted by v3rbatim99 View Post
    Hello,
    It says:
    PLC 372 > HALT
    Thnx a lot.
    Jul 2019
    Hello,
    I am experiencing the exact problem as v3rbatim99 with my Biesse Rover A3.
    The machine was working fine, but after a power supply unit replacement on the PC, the PC lost communication with the machine and I am getting the error:
    PLC 372 > HALT
    There seem to be no problem with the opertation of the PC and everything seems connected OK.
    I would greatly appreciate it if you kindly give me some feedback on how to overcome the problem.
    Thanks in advance.
  1. Biesse Rover error- Present sensor lacking
    By dbattaglia in forum Biesse
    Last Post: 01-21-2020, 02:44 PM
  2. biesse rover b 4.40 ftk plc 432 error ybn.1.2.6.
    By cutewinuscream in forum Controller & Computer Solutions
    Last Post: 09-04-2019, 07:27 AM
  3. cnc biesse rover 36
    By ylbermuhaxhiri in forum CNC Machining Centers
    Last Post: 01-30-2019, 10:30 AM
  4. Please please help! Biesse rover a3.30
    By XMARTYX in forum Biesse
    Last Post: 02-01-2012, 11:54 AM
