588,537 active members*
4,658 visitors online*
Results 1 to 5 of 5
    Mar 2012
    112
    Thinning acrylic solvent?
    Hey, I have some Weld On 16 here, which is the thicker variant. I was wondering, could you actually dilute it with acetone to obtain a thinner glue?
    Dan
    Build logs and other projects of mine: http://nqlasers.com/
    Oct 2011
    155
    The pds for Weld On 16 says it can be thinned with Weld On 3 by 10%.
    No, I dunno where to get Weld On 3 from either.....
    Could you just try the acetone and see what happens?
    Mar 2012
    112
    Did actually try it, poured out a bit of acetone and dropped in a bit of the #16. Appears to actually work, and does have the capillary action provided you don't add too much. It does take a bit of stirring/shaking to get it to mix, but it does seem to eventually.
    So far the bonds seem pretty strong, but I'll leave it a while to see how it goes.
    This place here seems to have it: IPS WELD ON 3 Acrylic Adhesive 473ML tin.
    Hmm, it does appear it may be causing a bit of stress cracking - not sure if that's from the acetone or what.
    Oct 2011
    155
    Well, THAT is embarrasing......
    I have been to Global Acrylics a few times. It is a one-guy operation, with limited stocks of acrylic, and just down the road from me.
    I am a dumbarse.
    I usually buy my acrylic and Weld On 16 from BFS Plastics, which is also just down the road from me and is run by a nice couple of older guys who cut the acrylic to size for me for free.
    Mar 2012
    112
    Yeah, there's a local place here I went down to about a week ago, they were nice enough to let me scrounge through their offcuts, pick a few bits, and they cut them small enough to fit in the laser cutter. Asked them about glue and they said they technically aren't allowed to sell it - something about people sniffing it (Of course).
    But yeah, just made a clear box to see if I could get it waterproof, and seems to have worked with the dissolved solvent, no leaks as of yet, just a bit of minor stress cracking.
    Definitely need to work on my application technique though, manage to spread the stuff all over the place. Need a little squeeze bottle instead of a syringe, would probably make it easier.
  1. Padovani Labor 255 lathe, thread plate wiped by solvent
    By cnc2 in forum Uncategorised MetalWorking Machines
    Last Post: 08-15-2022, 12:25 PM
  2. cleaning solvent
    By hmoore01 in forum Bridgeport / Hardinge Mills
    Last Post: 01-08-2012, 07:15 PM
  3. Chip thinning strategies, trochoidal toolpaths, high-speed machining using Mach 3?
    By 307startup in forum Mach Wizards, Macros, & Addons
    Last Post: 11-14-2010, 08:44 PM
  4. Replies: 0
    Last Post: 12-20-2006, 10:05 AM
  5. PVC - Solvent and oil tolerance?
    By Chris D in forum Glass, Plastic and Stone
    Last Post: 10-11-2005, 01:39 PM
