587,143 active members*
3,808 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Need help Puma 8s z-axis overtravel alarm
Results 1 to 9 of 9
    Jan 2010
    18
    1995 Daewoo Puma 8s S/N PM8S-0295 with Fanuc 0t control
    Z-axis overtravel alarm won't clear at all even with CAN-P upon bootup. We have tried....Powered down completely, Manually turned ball screw, Replaced z-axis limit switches. No E-stop button appears stuck. Pressed & held ready button & emergency release to power hydraulics, no success. Any more ideas please ???
    Jan 2010
    18
    Please - any ideas?
    May 2004
    4519
    Did you check for bad wiring yet?
    Jan 2010
    18
    Yes we've checked wire and continuity back to the board. Other suggestions anyone?
    Dec 2008
    239
    What is the alarm Number ? Is it Soft OT or hard OT alarm ? If it is a soft OT than CAN +P will work If not than you have to do other stuffs , Please confirm with alarm Number .
    regards
    [email protected]
    Jan 2010
    18
    #520 overtravel +z
    Thanks for any help
    Dec 2008
    239
    Try to increase the z + value to 99999999 in soft OT parameter , . in Puma 8 S some Bits are there where the CAn+P during power hold will not work , So try to increase the value of the Soft OT in parameter .or check the CAN or P button soft Keys ? Is it stucked ? or any other keys are stucked Like Soft KEy ?
    Regards
    [email protected]
    Jan 2010
    18
    Thanks for the tips, will go try parameter change and check for stuck keys now.
    Feb 2013
    788
    What are the values of parameters 1320 and 1321 for the Z-axis?
    When you press the Blue-emergency-release button and hold it, then press the machine ready button and hold it - Does the green <machine ready button> flash for 5 seconds and then turn solid? Does it continue to flash? or does it do nothing?
    If nothing while buttons are pressed, check the status of X8.1 (if X8.1=0 there is an ESTOP condition, check all switches and wiring)
    If X8.1=1 and the green button stays lit as long as the blue button is held in there is a "Hard Limit" alarm. Check for positioning, or limit switch function, or limit switch wiring.
    If 1320 and/or 1321 are set to a value other than the one from the Blue Book that came with the machine, (right down the current value) then set them to 99999999 (for positive soft limit) and -99999999 for negative soft limit. Press reset, if alarm clears - tuning is needed to set the soft limits to the appropriate location.
  1. alarm 510:overtravel X+
    By hell_pk in forum Fanuc
    Last Post: 02-29-2016, 09:28 PM
  2. alarm 500 overtravel
    By Datech in forum Fanuc
    Last Post: 04-07-2014, 10:08 PM
  3. PUMA 200 z axis overtravel
    By GEARHEAD73 in forum Daewoo/Doosan
    Last Post: 06-22-2012, 05:04 AM
  4. I have an overtravel alarm
    By eclarkmx in forum Fanuc
    Last Post: 09-04-2010, 12:43 PM
  5. Keep getting z axis overtravel alarm 146
    By dragon864 in forum Haas Mills
    Last Post: 07-21-2007, 12:13 AM
