Hi I was wondering if anyone is using Edgecam on a Wabeco mill? I am considering buying a Wabeco CC-F1410LF high speed CNC Mill for home use but only if I can generate programs for it using Edgecam. It uses G code & I have been told that a Fanuc om code will work on it. So I am in need of a post that will output the correct data. Or could anyone edit a post to give the correct output. I have a list of rules that the code must follow. The machine is supplied with nccad professional software, but will be better if I can use Edgecam. I think NCCAD is made by Kosy?
