Originally Posted by
ChrisAttebery
I've been using air blast and found that the feeds that FSWizard a suggests are pretty aggressive. Without flood you just won't be able to get the speeds he recommends. Off the top of my head I'd start at 350mm/Min and 1mm doc to start. Work your way up to 500mm/Min. Once you get to 500mm/Min start adding DOC. Others will tell you that's not right, but it is what has been working for me. make sure your air blast is getting the chips out of the way. I have been using 5psi through a .060" ID tube with the tip within 30mm of the end mill.
I've found that the sweet spot for slotting with my machine is about 30IPM/.060"doc/6000rpm with a 3/8" 3F carbide AL end mill. Smaller end mills are a PITA to slot with.
Yes you are absolutely correct.
FSWizard like any other calculator assumes proper if not ideal cutting conditions.
There is absolutely no way to cut aluminum dry at those feedrates!
And yes, i have found myself that normally in order to get in the ballpark for dry cutting aluminum you need to get SFM and Chipload to at least 50% each
Also your depth of cut will have to be reduced to half of recommended.
People have requested to add consideration for coolant into the calculator, but i am reluctant to do that as conditions will change for different materials.(IE: milling steel above 450SFM is dry only)
But with flood coolant i normally exceed recommended feeds, sometimes by as much as 150%
http://zero-divide.net
FSWizard:Advanced Feeds and Speeds Calculator
