588,507 active members*
4,994 visitors online*
IndustryArena Forum > MetalWorking Machines > Shopmaster/Shoptask > ShopTask under glass...Plexiglas
Results 1 to 20 of 20
    Aug 2004
    37
    Got tired of wearing coolant and chips around, so I built an enclosure.
    Its 60"x36"x48" tall.
    Attached Thumbnails Attached Thumbnails less doors.jpg   complete.jpg   left and back.JPG   back and right.jpg
    Very very nice. I only wish I could do the same for my 9' tall Bridgeport.
    Proud owner of a Series II Bridgeport.
    Aug 2004
    37
    Talking
    Quote Originally Posted by Cold Fusion
    You could...first start with a shower stall...j/k LOL
    Aug 2004
    37
    I still need to coolant proof a few things...move the lathe, X and Y axis motors 180 degrees about. feed thru's for wires and hoses. The list just gets longer and longer.
    How thick was the Plexi that you used?
    Aug 2004
    37
    .085" wall and doors.
    .110" roof
    Doors are kinda floppy.
    110 all around would be nice.
    Mar 2004
    847
    Quote Originally Posted by HogDog
    Ya know, that isn't all that bad of an idea really...
    Check Out My Build-Log: http://www.cnczone.com/forums/showthread.php?t=6452
    Nov 2005
    27
    How about noise.....
    .110" roof
    Does your enclosure reduce noise to any extent?
    Aug 2004
    37
    Quote Originally Posted by geoff p
    It does to an extent. The high frequency noise is alot less, but low freqs will always get by without futher dampening.
    I have the right side adjecent to an inside wall...lots of noise.
    Aug 2004
    37
    Lower shot of enclosure and leak test.
    It sits in a pan on plywood and a metal cabinet.
    Aug 2004
    37
    Holes
    punchin' out some holes and stayn' dry.
    Coolant is Rustlick 50/50 10:1
    Aug 2004
    37
    Dec 2007
    413
    Quote Originally Posted by HogDog View Post
    Is that arm attached to the head?
    Aug 2006
    111
    Question old threads?
    wow it only took you four years to ask that question. just saying.
    Aug 2009
    89
    I'm just trying to bury digital's rebuild thread and others.
    Good Luck
    Flathead
    Jan 2008
    458
    Quote Originally Posted by flatheadford49 View Post
    Good Luck
    Flathead
    No need, he pretty much buried himself. I've usually got several projects going on in my shop at any one time, but once in a while you just feel compelled to pick up all the tools, clean them and get them back in the toolbox. Then you wipe down the benches, grab the broom and sweep all the trash into a big pile and toss it into the garbage can. Its as good a feeling as completing one of the projects.
    Aug 2006
    111
    Quote Originally Posted by smallblock View Post
    i will be willing to bet you that it is not going to be that simple.(nuts)
    Dec 2007
    413
    Quote Originally Posted by norvil1 View Post
    Boy- you got that right. The problem is in the materials- plexiglass is not really ideal because it scratches easily and can turn cloudy with some chemicals. So for the front at least you need to use Lexan- which is also shatter resistant. The top panel could be plexiglass, since it only needs to allow the light to shine through. The back and end panels could be FRP for easy cleaning. For the newer machines which have the mobile bench on casters, the whole thing would have to be attached to the bench, or for wall mounting, some additional removeable panels ala roofing drip edge to contain the fluids. After pricing out the Lexan and other stuff, I'm thinking maybe just one of those heavy clear plastic shower curtains hanging from a circular rod might also work. Not too fancy, but cheap to replace and easy to take down and wash off in the driveway.
    Aug 2006
    111
    i ain't talking about the glass.
    Jan 2008
    458
    Quote Originally Posted by sharpshooter90 View Post
    You could even cut a couple of holes in it and attach a pair of long kitchen dishwasher gloves to the curtain- sort of like a sandblast cabinet, but with little daisies on them.
