Got tired of wearing coolant and chips around, so I built an enclosure.
Its 60"x36"x48" tall.
Very very nice. I only wish I could do the same for my 9' tall Bridgeport.
Proud owner of a Series II Bridgeport.
You could...first start with a shower stall...j/k LOLOriginally Posted by Cold Fusion
I still need to coolant proof a few things...move the lathe, X and Y axis motors 180 degrees about. feed thru's for wires and hoses. The list just gets longer and longer.
How thick was the Plexi that you used?
.085" wall and doors.Originally Posted by Cold Fusion
.110" roof
Doors are kinda floppy.
110 all around would be nice.
Ya know, that isn't all that bad of an idea really...Originally Posted by HogDog
Check Out My Build-Log: http://www.cnczone.com/forums/showthread.php?t=6452
Does your enclosure reduce noise to any extent?Originally Posted by HogDog
Originally Posted by geoff p
It does to an extent. The high frequency noise is alot less, but low freqs will always get by without futher dampening.
I have the right side adjecent to an inside wall...lots of noise.
Lower shot of enclosure and leak test.
It sits in a pan on plywood and a metal cabinet.
punchin' out some holes and stayn' dry.
Coolant is Rustlick 50/50 10:1
wow it only took you four years to ask that question. just saying.
I'm just trying to bury digital's rebuild thread and others.
Good Luck
Flathead
No need, he pretty much buried himself. I've usually got several projects going on in my shop at any one time, but once in a while you just feel compelled to pick up all the tools, clean them and get them back in the toolbox. Then you wipe down the benches, grab the broom and sweep all the trash into a big pile and toss it into the garbage can. Its as good a feeling as completing one of the projects.
Boy- you got that right. The problem is in the materials- plexiglass is not really ideal because it scratches easily and can turn cloudy with some chemicals. So for the front at least you need to use Lexan- which is also shatter resistant. The top panel could be plexiglass, since it only needs to allow the light to shine through. The back and end panels could be FRP for easy cleaning. For the newer machines which have the mobile bench on casters, the whole thing would have to be attached to the bench, or for wall mounting, some additional removeable panels ala roofing drip edge to contain the fluids. After pricing out the Lexan and other stuff, I'm thinking maybe just one of those heavy clear plastic shower curtains hanging from a circular rod might also work. Not too fancy, but cheap to replace and easy to take down and wash off in the driveway.
i ain't talking about the glass.
