There is no adjustment. Only on one end of one rail, because I needed a litttle bit of room to be able to get the rails through the end plates, as it's a very tight fit. The gantry and base torsion box ribs hold the pipes in place, and each is perfectly flat. (As flat as my 4 ft level, at least). There are threaded rods under the table holding the gantry sides tight to the rails.Originally Posted by Sanghera
