587,997 active members*
1,782 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Bridgeport Conversion And Liquid Tight Bulk Head Fittings
Results 1 to 5 of 5
    Mar 2013
    If you have put the new encoders with new cables on your Bridgeport, how did you bring the new cables in to the control box? The original bulk head fittings on mine were liquid tight. The ajax replacement cables have the end connectors already on them so I cant slip them thru a bulkhead fitting.
    Feb 2007
    198
    Hmmm....may want to pass that one by AJAX tech support to see what they do. I soldered my DB9 connectors on my cables after I slide on a watertite fittings.
    Mar 2013
    I did send this question to ajax a few days ago with no response yet. I will specifically ask how centroid does it on there complete conversions.
    Feb 2008
    280
    Centroid factory cabinets use a large entry slot in the bottom of the cabinet, with a clamping plate and neoprene gasket.
    You can fabricate something similar; or purchase pre-made solutions from Murr Plastik or others. See Cable Entry and Holding Systems
    If you are skilled with electronic connectors, you could also just cut and re-terminate your DE9 plugs.
    Dec 2022
    Re: Bridgeport Conversion And Liquid Tight Bulk Head Fittings
    Liquid-tight. Heat-resistant. Chemical-resistant. Secures vertical runs. Remke's complete line of cable strain relief connectors are in stock.
    https://www.superplasts.com/products/shopping-bags/
  1. Bridgeport Series I 2J quill too tight on reassembly
    By supahonkey in forum Bridgeport / Hardinge Mills
    Last Post: 01-21-2011, 04:12 AM
  2. tight threads with angle head
    By rylanrouge in forum Uncategorised MetalWorking Machines
    Last Post: 08-03-2010, 05:02 AM
  3. Bulk conversion, GE3 to MC9 ?
    By JohnF in forum Mastercam
    Last Post: 07-24-2007, 06:28 AM
  4. M head conversion?
    By teufel in forum Bridgeport / Hardinge Mills
    Last Post: 01-11-2006, 02:44 AM
