587,739 active members*
3,203 visitors online*
Results 1 to 16 of 16
    Sep 2003
    25
    lego cnc mill
    Hello everyone,
    I've just found this site; I'm really impressed. Anyhow, I'm about to begin construction on my third mill. I thought you might be interested in a few pictures from my second. As you can see it's mostly made out of lego bricks. The only thing not made out of legos are the dremel and the three stepper motors. The steppers are computer controlled via a motor controller I built.
    I'm pricing parts for version three now. I already have the new stepper motors. These are NEMA 23, the lego mill used NEMA 17s. At 3 amps per phase, I'll have to build a new motor controller and get a new power supply. I have the parts for that picked out, too. I plan on getting a surplus graphic LCD display for a digital read out. Suppose it doesn't matter, since I don't have (read can't afford) encoders I won't be able to operate it by hand, but seems like a nice feature...
    Anyhow, I'll let you know how it goes when it gets going.
    Sep 2003
    25
    Here's the side
    Sep 2003
    25
    and the top
    6855
    Woo, way cool, who would of taught to make one out of legos.
    2139
    Sweet. Have you cut stuff with it?
    Eric
    I wish it wouldn't crash.
    Sep 2003
    25
    Well, of course ...but there are a few problems. As you can imagine there's a bit of backlash. The yellow springs on the gantry were added to help with that, and did a little. And of course the dremel is not held as tightly as it should, but it is actually secured really well, for legos. Also the gantry is also heavy, so I had to really torque up the y-axis motor so it would move. It uses 2 screw gears, so the gear ratio is more than 576. SLOW... The x-axis is much faster and lighter. z-axis is also no problem.
    My goal is to mill circuit boards. I'm an electrical engineer, and just starting to pick up this mechanical stuff. The lego mill did help me learn a lot. A good place to start before the bigger investment.
    4826
    Apollo
    LoL, you should sell the plans for the Lego machine, maybe that's your calling
    First you get good, then you get fast. Then grouchiness sets in.
    499
    Hey Apollo...
    Is this you:
    http://www.ozbricks.com/bobfay/newmill.htm
    There is actully a 5 axis mill on this site.
    PEACE
    Sep 2003
    25
    No, not me, but I had seen that site before.
    I think I might have been ambiguous before, the next mill won't be made out of legos.
    Apr 2003
    470
    Here's one made from K-Nex
    Nathan
    Aug 2003
    94
    very nice
    2139
    Do the Lego people know about this?
    Eric
    271
    seems like the dremmel would vibrate everything loose!?
    My little piece of the web!
    http://users.adelphia.net/~wjdupont
    Sep 2003
    25
    No, the dremel is quite well supported. It doesn't vibrate any noticable amount. Although I'm sure that if I ran it long enough, the legos might start to melt.
    I'm pretty sure that the lego people don't know about this one. They might be more interested in the one that hardmill gave the link to. That one is 100% legos. Though I didn't have much use for a toast cutter...
    Jul 2005
    4
    I am extremely new to cnc. From the research I have done on CNC machines, I though hey why not build a CNC out of legos. Being a poor college kid it would make sense with my limited resources. I just joined this site to learn more. Low and behold what do I find, that my bubble has been popped. I am thinking 3 axis and my dremel it will only be used for small projects workspace about 6 X 12. I have not bought any materials yet though I am definitely intrigued. Thanks for the inspiration!
    Nono Guest
    You know they pay big bucks to people that build this stuff. There are guys that work for lego that all they do is build things and make prints. Most of them are not kids (at least not by age) and get paid more the a hundred K a year to play with toys isn't to shabby. You are my Idle :cheers:
  1. Using your CNC Mill as a CNC Lathe
    By lstool in forum Knee Vertical Mills
    Last Post: 06-12-2017, 02:29 PM
  2. Which CNC Mill and what software?
    By MaxxMan-X in forum Knee Vertical Mills
    Last Post: 12-31-2014, 04:27 AM
  3. Pictures of My Lathe & CNC MILL
    By studysession in forum Uncategorised MetalWorking Machines
    Last Post: 01-04-2005, 11:07 PM
  4. Need to CNC my mill quickly - advise?
    By SRT Mike in forum Uncategorised MetalWorking Machines
    Last Post: 03-15-2004, 07:10 PM
