587,591 active members*
4,453 visitors online*
Thread: FLA100 Build
Results 1 to 3 of 3
    Jan 2007
    25
    FLA100 Build
    Extreme Newbie here building the FLA100.
    I purchased the extruded aluminum from 8020 Inc. on eBay and drilled and tapped the holes on my drill press.
    I purchased my rails from Stock Car Steel also on eBay. They cut the steel to length and I drilled the holes.
    The hardware came from BoltDepot.com.
    CNC Router Parts is where I purchased the linear carriages, motor mounts, z-axis plate, acme-nuts, oldham couplers, and the shaft adapters needed.
    McMaster Carr is where I bought the 5-start ACME Lead screws, shaft collars, and thrust bearings.
    I have assembled everything but am waiting on the motors and electronics to show up. Can't wait to see it run.
    Here are a few pics from my build.
    Attachment 182924Attachment 182924Attachment 182926Attachment 182928Attachment 182930
    Apr 2003
    550
    Great progress looking forward to cutting.
    Keep up the pictures!
    Jan 2007
    25
    Received my K2 mount for my Porter Cable 892.Click image for larger version.
Name:	ImageUploadedByTapatalk 21370476100.807881.jpg
ID:	187074Click image for larger version.
Name:	ImageUploadedByTapatalk 21370476119.615731.jpg
  1. Modified FLA100 Build Looking For Input
    By mhodder in forum DIY CNC Router Table Machines
    Last Post: 04-18-2013, 09:16 PM
  2. FLA100 - 3D PRINTER CONVERSION
    By CNC74 in forum DIY CNC Router Table Machines
    Last Post: 01-09-2013, 04:40 PM
  3. FLA100 build q's
    By dekalb in forum DIY CNC Router Table Machines
    Last Post: 06-30-2012, 02:11 AM
  4. FLA100 CNC Router For Sale
    By zeeway in forum Open Source CNC Machine Designs
    Last Post: 08-29-2011, 09:43 PM
  5. FLA100...What to go with it?
    By jason75 in forum DIY CNC Router Table Machines
    Last Post: 02-07-2011, 12:46 PM
