587,872 active members*
3,283 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Controlling a Red, Green, Yellow stack light w/ Mach 3
Results 1 to 12 of 12
    Feb 2010
    3447
    http://www.automationdirect.com/adc/...0mm_Components
    Would it be easy for mach 3 to control a Reg Green Yellow stack light?
    Anyone done it?
    Apr 2007
    8082
    Are you talking about directly from Mach3, or through gcode commands when a job is running?
    Mach3 - A VB script can be written to detect when the Run, Reset, or Pause status is active and maybe send that signal to a breakout board.
    Gcode - Gcodes for functions that you don't otherwise use could be used. There are user definable gcodes also. you would need a board to translate the signals to control the lights or LEDs.
    I'm no expert on this subject but I think there are possibilities.
    CarveOne
    http://www.carveonecncwoodcraft.com
    Feb 2007
    4553
    Quote Originally Posted by diyengineer View Post
    Anyone done it?
    Pairing a PoKeys56U with solid state relay's (SSR) would be a elegant solution even though it might be a bit of overkill.
    https://www.sparkfun.com/products/10636
    http://www.poscope.com/pokeys56u
    Having 55 digital I/O at your disposal and only one USB cable or Ethernet connection back to your computer makes for a very clean installation.
    Duncan at CNC4PC stocks the entire line with all of the accessory products too.
    http://www.cnc4pc.com/Store/osc/index.php?cPath=54
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Dec 2006
    532
    I'm in same boat, and would like to have stack light on my machine, but at the moment really could use yellow light when M1 is active, does anyone have solution on how to go about doing this?
    Thanks,
    Feb 2005
    487
    There is an easier way........
    all you need is 3 outputs off of your break out board, (second para port may be needed), or usually an SS or ESS will have the outputs extra.
    In Mach3 build a "Brain" for your stack light, conditions, on the output side, since most stacks are 24v. You would need to use 3 relays to pass the signals.
    Brain would be:
    (the below resetled and m1led are inverted and and'ed together)
    ResetLED->invert
    >and ->output4 (green light)
    M1Led->invert
    M1Led->output5 (yellow light)
    ResetLED->output6 (red light)
    you could use brains to add complexity or other conditions as well.
    Scott
    Commercial Mach3: Screens, Wizards, Plugins, Brains,PLCs, Macros, ATC's, machine design/build, retrofit, EMC2, Prototyping. http://sites.google.com/site/volunteerfablab/
    Feb 2010
    3447
    Say i only have 1 output port free. How do i expand that port into more?
    Dec 2006
    532
    Second parallel port or PoKeys is what I use.
    Feb 2010
    3447
    No 2nd port on the BOB. Looks like ill have to use POKEYS for expansion.
    Dec 2006
    532
    Thats what I mean, you get second parallel port(a expansion card for your computer), and another BOB and you got more I/O.
    But Pokeys is good option also.
    Feb 2010
    3447
    (chair)
    haha
    opps!
    I didn't even think about using a 2nd BOB on another parallel port! That would be a quick way of doing it too.
    Dec 2003
    24220
    Have you looked at a Modbus fix for expanded I/O?
    There is a stack light example
    http://www.google.ca/url?sa=t&rct=j&...YRqkjeEwfGAc9A
    Al.
    Albert E.
    Dec 2006
    532
    This is close, but I dont think its exactly what I need, and I don't know enough about this stuff to modify to my needs, and I think i worded my goal wrong,
    Basicly I got this one 2 axis mill, so when there is Z change or tool change I put in M1's in the program, so I would like to be able to see when its time to change tool or reposition Z without having to walk over there but just glance at the stack light.
    Is something like this possible?
    Thanks,
    Russ
    Quote Originally Posted by PoppaBear10 View Post
    Brain would be:
    ResetLED->invert
    M1Led->invert
    Scott
  1. Cant make sense of this light stack wiring
    By Skiroy in forum CNC Machine Related Electronics
    Last Post: 08-25-2011, 03:49 AM
  2. G540 Green Light..Go or no go?
    By ronncat in forum Gecko Drives
    Last Post: 01-02-2010, 08:11 PM
  3. How now the Light Green cutting fluid
    By cnc_swe in forum MetalWork Discussion
    Last Post: 08-25-2009, 03:57 PM
  4. green light in mdi mode
    By davek in forum Fanuc
    Last Post: 07-27-2009, 11:54 PM
  5. Led light stack burned out on SL-10
    By Edster in forum Haas Lathes
    Last Post: 10-06-2007, 12:27 AM
