588,243 active members*
4,245 visitors online*
Results 1 to 12 of 12
    Feb 2013
    51
    Z axis coupler and Dragon Cut steppers
    I bought the Dragon Cut 620 oz stepper motors and when I ordered the z axis off of ebay I didn't notice that the Motor shafts are 3/8" but the z axis coupler is 1/4".
    Is there a coupler that will go from 3/8" to 1/4"?
    Or is it possible to switch the shaft on the stepper around since the shaft sticks out the opposite side of the motor mount is 1/4"
    Thanks,
    Frank
    Dec 2007
    2134
    I most definitely wouldn't be pulling apart the stepper. 3/8" to 1/4", 1/2" to 1/4", etc, are all standard sizes, just need to trawl ebay to find a good priced one, probably around the $10 mark I'd guess based on the ones I've bought.
    cheers, Ian
    It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
    35538
    McMaster Carr has many types of couplers that will go from 3/8" to 1/4"
    Feb 2013
    51
    Thank you sirs, I knew someone would have the answer. I have been busy and haven't had time to look until today.
    Jan 2006
    105
    Can you not just drill out the coupler to 3/8"? I have the same motors and probably the same eBay Z assembly and I just noticed the coupler problem. They look like there is plenty of sidewall left even if drilled out. I'll try it and see if it works.
    2000 Haas VF-2 : Tormach PCNC1100 :OneCnc XR5 Pro
    Jul 2012
    64
    Yes that would work just fine. I would at least bore it out with a drill press, or a mill if you have one. A hand drill and vise may not be as precise as a guy would want.
    Quote Originally Posted by partsman View Post
    Feb 2013
    51
    I have been working out of town a lot lately and haven't had time to work on it. I'll look at drilling it out but they have stress cuts to make it the weak link so I'll have to be careful it doesn't catch in the bit and snap it off at the stress cuts.
    I should be able to work on it this weekend then I have another trip planned the week after. If it weren't for time and money I'd have it completed by now.
    Jan 2006
    105
    I tried to drill mine out in a drill press but failed. The coupler is aluminum and the bit ended up cutting more on one side than the other for some reason. It might have worked if I gradually went up a size at a time. Not sure. I just ended up ordering a 3/8" coupler from Velox on ebay. It was only $10.
    Feb 2013
    51
    Did yours have the stress cuts in it? This is what I currently have. New 5mm x 5mm Shaft Coupling CNC Stepper Motor Flexible Coupler Clutch | eBay
    Jan 2006
    105
    No. Mine had the three piece style with the little plastic "T" piece in between the two aluminum couplers.
    Sep 2011
    54
    Frank contact velox cnc on ebay and see if they can get you the coupler you need.
    Travis
    Feb 2013
    51
    Thanks Travis. I'll get one ordered up this week.
  1. My Dragon Cable Project (E-Chain)
    By msimpson99 in forum DIY CNC Router Table Machines
    Last Post: 09-13-2011, 09:34 PM
  2. Dragon cut question
    By tentonjj in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 07-15-2011, 12:51 AM
  3. Dragon Driver ramp capacitor
    By BTD in forum Stepper Motors / Drives
    Last Post: 07-27-2010, 12:09 AM
  4. changing z axis motor coupler on the x4+
    By ataxy in forum Syil Products
    Last Post: 08-07-2009, 11:57 PM
  5. SX3 Z axis won't move (4/20 Problem solved-Coupler)
    By metalworkz in forum Syil Products
    Last Post: 04-27-2008, 04:52 AM
