Spindle speed for Sieg conversion
I have a Sieg X3 converted and running on Mach 3, my question is about controlling the spindle speed with the variable speed board on the X3.
The speed is adjusted by a 4.7K pot and has a switch for cw/ccw.
Could I wire a relay to the output pins for CW/CCW and use PWM to emulate the 4.7K pot and use a simple encoder for rpm feedback?
Did you find the answer?
I am also wondering how to do this
yes, you could do that, you could use a digispeed for the pwm input and controller and a relay controlled by m3 m4 and m5 to controll the direction.
I doubt its healthy to switch it while in motion though.
Jon
I just emailed them over at http://www.homanndesigns.com/index.html about the digi speed.
I'll let you both know what the get back to me with
I have been in touch with Peter Homann and he seems confident the digispeed is going to work, I have emailed him schematics for the X3 for further clarification.
I'm going to order one, I'll let you know how it goes
Randy
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
