587,546 active members*
3,820 visitors online*
Results 1 to 3 of 3
    115
    Ceramic Inserts
    Are there any super alloy milling fools out here that are aware of a .250 dia.
    milling insert? I checked Kennametal. Their smallest is .375. I tried Greenleaf website but the "contact" page is not working properly. (returns an error when I push the "submit" button.)
    I am looking for a 1" or 1 1/4" dia. milling cutter (3 flute?) for .250 round ceramic inserts.
    I am presently using Kennametal 1/2" round inserts. Application is roughing into a square shoulder. (step) Part materials are Hastalloy X and Nimonic 263. Toolpath is approx. 24 inches long, one inch or less deep. The finish part needs a .125 corner fillet radius. As is is now, I need to semi-finish with carbide inserts to remove the .250 Rad. left behind by the ceramic inserts, before I run the final finish tool with a .125 rad. (The .25 rad. is too much for the finish tool to deal with.)I want to be able to rough with ceramic that has a .125 rad. and eliminate the semi-finish tool.
    This smaller dia. would also enable us to increase SFM as well as eliminate a semi-finish tool.
    We are currently cutting Nimonic (C-263) at over 3000 SFM. Using the Kennametal 1/2" round insert, in a 2" dia. 3 flute cutter body, the sweet spot seems to be 6050 rpm
    66 ipm. .125 doc .500+ radial doc.
    I would need an off the shelf item because of time constraints combined with frugal...........no...."cheap" management here.
    ie. : If ya gotta make it special it probably won't do me any good.
    "The source of expertise is not in the memorization of the minute details of a subject but in the thorough understanding of the fundamental concepts on which it is based." --author unknown
    927
    You might try these guys. I have used thier inserts on Nickel alloys with good results. I also keep some around to use if I need to "neck" down a tap or hss mill.
    Couldn't find a web site, only the main one, not the one spesific to cutting tools.
    N T K Cutting Tools
    39205 Country Clb Dr
    Farmington Hills, MI 48331
    Phone (248) 489-0123, Fax (248) 489-0095
    115
    wms thanks.
    I've been told there's no such thing. Too small. And after
    thinking on it some more, I'm not going to gain as much as I thought (if anything) anyways. First of all I need to correct myself above. The sf will be the same. It's the speeds and feeds that will increase due to smaller cutter dia. And conversly I'll be taking 1/2
    doc. and less chip load. So... I'll be moving not quite, twice as fast, but taking twice as many cuts.
    IF that is true, THEN I may not even be able to loose the semi-finish tool, because I would have still roughed with the bigger tool agressively and semi-finished with the smaller ceramic.
    It was a win, loose, loose deal.
    I'm gonna try somthing else.
  1. Need help finding these inserts
    By Hack in forum MetalWork Discussion
    Last Post: 03-16-2005, 05:08 AM
  2. Machining Invar 36
    By Kosta1234 in forum MetalWork Discussion
    Last Post: 02-25-2005, 05:03 AM
  3. Lathe tools
    By cncadmin in forum DNC Problems and Solutions
    Last Post: 05-26-2003, 06:18 PM
