587,822 active members*
2,925 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Xzero CNC > Calibration and accuracy testing of a Viper X
Results 1 to 12 of 12
    Jul 2003
    138
    I will be shooting a series of videos showing how to calibrate and demonstrate the accuracy of a Viper X CNC Router.
    The initial testing will make use of MACH 3 and its axis calibration feature. I have also included some photos of the stepper driver I am using and its settings.
    The first test is with .1" of travel.
    Jul 2003
    138
    The second test is with 10 inches of travel.
    Jul 2003
    138
    Aluminum cutting and MACH 3 probe
    Doing some work with the Viper, this time I am expanding the size of some holes in a mounting plate for my predator. Made use of the touch probe feature in MACH3 to center the cutter and set the Z axis depth to be the bottom of the hole.
    Jul 2003
    138
    Jul 2003
    138
    May 2008
    4068
    Are you machining holes in the plate?
    XZero cnc
    Jul 2003
    138
    No, just expanding existing holes to fit an M8 bolt head.
    May 2008
    4068
    Quote Originally Posted by ngr1 View Post
    To M8? don't think they will fit, you would have to put bolts in plate before putting spindle on plate
    XZero cnc
    Jul 2003
    138
    2.5D Capability
    I wanted to show the accuracy and 2.5D capability of the Viper in this post. In the link below I came across a cool 2.5D part that was being cut on a Mill so I asked the owner (UniqueMachining) if he would share it with me which he did. Thanks again John!
    The part was cut in 20 minutes and the feeds were setup up for aluminum so I could have cut it in less the half the time. There were 3 tools changes but I cut the part with a single tool which was a 1/4" ball nose. The rounded part of the cut was super smooth and so was the rest of the piece.
    http://www.cnczone.com/forums/novako...wn_cruise.html
    Attached Thumbnails Attached Thumbnails DSC_0726.jpg   DSC_0727.jpg   DSC_0728.jpg
    Jul 2003
    138
    Cutting aluminum
    Cutting some more aluminum now. 30 ipm with .03" depth cut with no problems.
    The images below are of a spacer I am making for my predator.
    May 2008
    4068
    Cutting nice for small machine
    XZero cnc
    Jun 2007
    3891
    Quote Originally Posted by gio666 View Post
    the mass of the vise is going to help alot. with the part just clamped to the table, its would probably have more vibration. more weight = more better
  1. Replies: 0
    Last Post: 03-08-2011, 12:28 PM
  2. Design accuracy to mechanical accuracy
    By kbayram in forum Linear and Rotary Motion
    Last Post: 08-18-2010, 09:34 AM
  3. Renishaw touch probe calibration and accuracy
    By gpcoe in forum Haas Mills
    Last Post: 06-29-2010, 09:50 PM
  4. Testing, Testing 1 2 3... My last post disappeared.
    By Tom Kay in forum DIY CNC Router Table Machines
    Last Post: 02-22-2008, 06:30 PM
  5. Accuracy determination & accuracy improvement
    By rweatherly in forum DIY CNC Router Table Machines
    Last Post: 08-11-2005, 02:37 PM
