587,997 active members*
1,516 visitors online*
Page 2 of 2 12
Results 21 to 29 of 29
  1. #21
    Mar 2012
    276
    These 1/16 ball nose work very good for 3d stuff. Dremel bits generally suck for CNC.
    Korea Import 1101 7760 1 16" 2 Flute Carbide TiAlN Coated Ball Nose End Mill J6 | eBay
    My CNC Router Build - http://tinyurl.com/c3vs3ca
  2. #22
    Apr 2013
    18
    Thanks for the link. The seller indicated that he can ship to South Africa. Are these cutters good quality carbide cutters that can be used on hard woods? They are much cheaper than anything I can buy locally!
  3. #23
    Apr 2013
    18
    First MDF model of Chess Knight
    First complete model of Chess Knight milled from MDF. Took about 3 hours to complete. First a rough cut with a 3mm Dremel bit, followed by a finishing cut with a 1.4mm bit. Quite satisfied with the result. A fourth axis will nicely take care of the region between the ears. Any feedback on the quality of the Chinese fourth axis units available on Ebay will be appreciated.
    Also need to figure out feed and spindle speeds when cutting with real ball nose cutters in hard wood like Madagascar Ebony.
  4. #24
    Apr 2013
    18
    Addition of 4th axis
    Just received my 4th axis drive and tail stock ordered from China. Seems solid and sturdy enough and should be perfect to cut the chess knight using indexed cutting with DeskProto, and also to cut the rest of the chess pieces. Should have it fully integrated by the end of the weekend.
  5. #25
    Apr 2013
    18
    Accurately drill holes in alluminium mounting plate for 4th axis
    Quite satisfying to use the CNC machine to accurately drill the mounting holes in the 8mm aluminum mounting plate for the 4th axis!
  6. #26
    Apr 2013
    18
    4th axis mounted - ready to connect stepper motor to G251 Geckodrive
  7. #27
    Apr 2013
    18
    G251 GeckoDrive for fourth axis integrated with G540 GeckoDrive - ready to roll!
  8. #28
    Apr 2013
    18
    First cut with 4th axis - still need to figure out how to set up properly
  9. #29
    Apr 2013
    18
    Complete set of black chess pieces
    Completed machining the first set of 16 black chess pieces out of Madagascar Ebony. Also machined a piece holder out of foam. Average machining time per piece about 2 hours.
    Attachment 197798
    Attachment 197800
Page 2 of 2 12
  1. Just another CNC router from T-slot aluminum
    By pilotarix in forum T-Slot CNC building
    Last Post: 02-05-2013, 07:19 PM
  2. one slot is coded other slot is not there
    By cwaugs in forum Uncategorised CAM Discussion
    Last Post: 05-06-2011, 03:00 AM
  3. cutting a slot with a t-slot cutter
    By cncuser1 in forum Mastercam
    Last Post: 09-10-2008, 03:02 AM
  4. T-slot Router Bed Extrusion
    By gotswrv in forum Want To Buy...Need help!
    Last Post: 07-11-2008, 02:16 AM
  5. Replies: 7
    Last Post: 04-12-2007, 03:00 AM
