588,147 active members*
6,087 visitors online*
Results 1 to 6 of 6
    May 2011
    53
    Haas TL1 Loosing Z Position
    Hi to you all, we have a small problem with the TL1 Lathe. When we power it up on a morning, sometimes it has problems referencing the Z axis, the saddle will move slowly in a Z+ direction as it should but then instead of stopping, the saddle will then creep forward in a Z- direction and would not stop unless we hit reset. This happens occasionally but the real problem is, we are finding that all the tools seem to be loosing their Z axis offsets on a regular basis, like every time we power off and on.
    We are finding that the Z value for the same tool changes every time we power off and on, this combined with the "Z- saddle creep" makes me think it could be a problem with the home position referencing.
    I am sure it is something simple like a piece of swarf on the limit switch which is causing the problem but i don't know how to find the switch. Could someone tell me where it is?
    Many thanks
    Jul 2005
    12177
    Look behind the bed toward the tailstock end and you will find the proximity sensor. Your problem is almost certainly due to a build up of chips in the metal trough that runs along the back of the bed. I will try to find the picture I posted years ago about this problem.
    Here we are: http://www.cnczone.com/forums/haas_l..._position.html
    The pictures were taken from the back of the machine.
    May 2011
    53
    Thanks Geof, got it sorted.
    Feb 2010
    1184
    Quote Originally Posted by pbd1971 View Post
    So was the issue chips on the switch? It is always nice to hear what the solution to a problem is.
    Also, it is helpful when someone searches for a similar problem down the road.
    Glad you got it figured out though.
    May 2011
    53
    Quote Originally Posted by haastec View Post
    Yes, that was the problem, lots of swarf and acetal dust all over the switch. We gave it a good clean down and so far, no more problems.
    Jul 2012
    8
    Make sure to do it on the x axis as well
  1. Precix Router Loosing Position
    By PeterMole in forum Commercial CNC Wood Routers
    Last Post: 09-09-2014, 07:57 PM
  2. "Z" axis loosing position
    By blackc1 in forum Fadal
    Last Post: 06-06-2013, 08:46 PM
  3. G340 X axis loosing position..don't know what to do!
    By Alex_Cole in forum Gecko Drives
    Last Post: 12-10-2011, 05:24 PM
  4. Replies: 3
    Last Post: 12-31-2009, 11:01 PM
  5. EZTRAK Y axis loosing position, "slipping"
    By melamark in forum Bridgeport / Hardinge Mills
    Last Post: 12-18-2005, 08:23 PM
