Designed and built my vacuum table using (2) 3/4" sheets of MDF. Cut all pockets, grooves, grid, etc., and put about 4 coats of shellac on it. My grid is closer to about .237 wide by .200 deep. I am using .250 EDPM closed cell cord from McMaster Carr. When I put it in the grid it always leaks right at the joint. I turn both ends to the left (one left and the other right as you are looking at them) so they pass by each other at the same intersection. I also put a little twist in the cord at each bend to help keep it from lifting. I am using the Thomas pump kit from Joe Woodworker. I get to about 25" of mercury but it slowly drops. I can hear where it leaks from and have moved the cord so the joint is at different locations and it always leaks where the joint is at.
Ideas/suggestions?
