Originally Posted by
Jacala
Hello!
I'm building a simple tube cutter/notcher running on Mach 3 and I'm looking for some information.
The size (dia) of the tubing would depend on whether this idea is feasible, But I would look at a lathe type machine where the spindle can also be switched over to C axis, either by using a servo motor on the spindle or a small separate motor for the C axis when in use.
And standard interpolated motion would be used for the C, X & Z axis, live tooling would enable the engraving and notching, in the spindle mode this would act in a cut off mode.
Al.
Albert E.
