587,999 active members*
2,270 visitors online*
Results 1 to 6 of 6
    302
    Self cleaning Filter
    With the possibility of running my (future) 3-axis wood router in my spare room in my house, I was considering an enclosure/filtering system. Has anyone else designed and/or completed one of these? If I can figure out how to insert an image, I'll try to show you a quick idea I had that should be fairly maintenance free. Your thoughts?
    Rance
    35538
    If you're running it in the house, you'll want it completely enclosed. Especially if you cut any MDF with it.
    To insert an image, click the "manage attachments" button. Browse to the file, and click the upload button. Once the uploading is complete, you can send the message.
    Mar 2004
    847
    Hmm, that is pretty neat idea. Although, even with cheap TP, that'll get expensive.
    The other problem I can see is that TP breaks pretty easily.
    Now, if you do make your machine fully-enclosed - there really wouldn't be a need for the elaborate set-up. Just a Shop-Vac to clear the dust out, and an intake (Dryer Vent?) to bring fresh air in.
    Oct 2005
    1238
    Uploading Image ???
    Quote Originally Posted by ger21
    Ger, I cannot seem to upload an image using this method.
    System says it is "uploading" but image isn't in the message after a "send."
    Your suggestions????
    Thanks WT
    Dec 2003
    430
    A totally enclosed machine is the way to go, greatly reduces noise too.
    Here are a couple of pictures of my soon to be retired machine. It will be replaced by a much updated version in the next couple of weeks.
    Here is the build thread, there is a video in there too on the second last page. http://www.cnczone.com/forums/showth...design+process
    When uploading, give it a minute to complete the upload before closing the "manage attachments" window.
    Colin
    Oct 2005
    1238
    Colin
    Thanks for the hint, I'll try that again.
    Nice machine! I wish you well on the updated version.
    WT
  1. Cleaning ZnSe lens
    By cncadmin in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-08-2011, 03:24 PM
  2. Need Source for Cheap PS Filter Capacitors?
    By Bird_E in forum CNC Machine Related Electronics
    Last Post: 02-08-2005, 07:29 PM
  3. Calculating Filter Capacitance
    By CapnC in forum CNC Machine Related Electronics
    Last Post: 01-05-2005, 01:40 AM
