Attachment 188280
Attachment 188278
Hi, I started a project that will use a pendulum to drive a flywheel. I am using an over run clutch between the pendulum and flywheel so the flywheel will only rotate in one direction. The pendulum only adds power the flywheel when it swings in one direction. I am searching for a method or design that will allow the pendulum to add power to the flywheel as it swings in both directions. Suggestions welcome.
