587,218 active members*
2,860 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > okuma osp 5000 bus error and cycle error led on
Results 1 to 11 of 11
    Mar 2012
    15
    Hello all
    i have this led on cpu rack on and the screen is like foto bellow when starting machine
    machine is Okuma MC 4VA OSP5000-G
    Attachment 191940 and the screen is Attachment 191942
    this was
    happened during work some parts in auto mode
    Before this event I had other interruptions solved with a power of
    such as would be the picture below
    Attachment 191946 and Attachment 191944
    thanks in advance
    can someone help me with some tips on where to fix the problem ?
    Mar 2009
    1982
    Maybe cleaning of control modules could help. Clean the rack connectors also.
    Mar 2012
    15
    I already cleaned the connectors on the boards of the rack and still does not start
    battery is 3.7v is ok
    Mar 2009
    1982
    Check power supply stability or try other ±24V PSU. Try re-installation of Okuma software.
    I changed the CPU board (200US) it helped me.
    The lathe worked more then half year.
    Nov 2016
    42
    Re: okuma osp 5000 bus error and cycle error led on
    hello
    i have the same problem could you help me
    Change the board. But if you can no do it change CNC to China. It will be more cheaper then buy board.
    Nov 2016
    42
    Quote Originally Posted by =aike= View Post
    Thanks what do you mean Chang cnc to China?
    Which board I have to change?
    Please name the board.
    I remove all OKUMA CNC with servo motors and drivers and install new China CNC TD1000 with 2 new servo motor and 2 new servo drive.
    I have no any problem now.
    Jun 2015
    4156
    hy aike this is the 2nd time i hear about someone replacing the cnc
    here is the other : https://www.cnczone.com/forums/okuma...ml#post2076724
    i think is a god idea ( especially if you can do it yourself ), to bring back to life an older model; thus if machine/mechanical is ok, then why not just rewire it ? kindly
    Nov 2016
    42
    Hello
    Could you name the board name please?? Where is the cpu exactly ( which board hold the CPU)
  1. Use cycle simulation time error
    By pinguS in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 04-14-2011, 07:53 AM
  2. Need help Mazak Tap Cycle Error
    By Payhoe in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-18-2011, 02:33 PM
  3. Mori MV-JR Power off during ATC cycle error
    By dddamian in forum Fanuc
    Last Post: 09-23-2009, 03:17 AM
  4. okuma 2008 error. DMA transfer does not complete within a specified cycle time.
    By mikul in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-28-2007, 05:36 PM
  5. error in drill cycle
    By TPPJR in forum OneCNC
    Last Post: 01-28-2006, 07:21 PM
