Hi guys, I have a problem renting or finding a place to run my homemade CNC machine to cut foam... so the only solution Ive come up with is doing it in a cheap van... sealing the space into two sections and running the machine with the power source supplied from a generator.
My question is will any low end generator be able to power the following setup?
Things needing electricity
Router - power 9.5A motor, 1-3/4 hp
CNC electronics and motors - Kelling kit with ~380 oz motors.
............3 NEMA 23 Motors
............36VDC/ 9.7A Power Supply 110VAC/220VAC
............GeckoDriver
Mini computer tower
Lap top - networked as monitor
Small vacuum, but not necessary.
Misc power rating chart
