587,507 active members*
2,940 visitors online*
    Mar 2012
    61
    RF45 max table load
    Hi, been searching but cannot find this infos anywhere. What would be the practical limit of weight that the manual RF45 style mill tables can handle?
    Rgrds
    Mar 2012
    61
    Anybody?
    Sent from my iPad using Tapatalk HD
    Jan 2009
    265
    If the load stays centred, probably about 200kg, if the load travels to X axis extremity, i'd say 100kg because you are then applying a bending load on the table.
    Bent tables are not good.
    Mar 2012
    61
    Hi DL,
    Thank you kind Sir. I was looking to load to between 150 and 200Kg on the table. Since its a long bed (1000mm) I will keep the lengths to 500mm centered on the table if it weights more than about 100Kg.
    Rgrds
  1. RF45 overall stiffness
    By sgt panties in forum Uncategorised MetalWorking Machines
    Last Post: 08-06-2011, 03:56 AM
  2. looking for any reasons not to buy an rf45
    By lost_cause in forum Benchtop Machines
    Last Post: 06-15-2010, 03:30 PM
  3. My New CNC RF45...
    By GMitchell in forum Australia, New Zealand Club House
    Last Post: 09-08-2009, 05:02 AM
  4. Best Table Setup to Load Materials
    By schoobie in forum Torchmate
    Last Post: 06-09-2008, 04:12 AM
  5. HELP selecting MOTOR size 1 AXIS 8 ft table with load 1000 lbs
    By cjchands in forum Mechanical Calculations/Engineering Design
    Last Post: 08-08-2007, 02:27 AM
