Hello
Can anyone help me get this machine going.
I can zero return axis but I get these ALARMS. See picture
Hello
First off, put some numbers in the tool data to get rid of the stars. The machine is over traveled in both axis. Move them minus with the hand wheel while pushing in the over travel release button. (blue push button) Make sure them way lube tank is full. Pump it by hand by pulling the plunger up 3 or 4 times to prime the system. Nothing is going to move until the lube alarm is cleared. If that doesn't work let me know. I live by LITH and could stop by.
Mrmazak.
I can't send you pm.
Check the parameter screen, if you have asterisks in any of these, you need to reload all parameters.
Hopefully you have them?
Al.
Albert E.
I have some for an SL-40 that may help.
Write down the ones you have first.
The OP para have to be entered with a 9 digit that includes parity number for e.g. OPx 010001013
Al.
Albert E.
How to clear asterisks on T1. You will need to take note of parameters first.
to clear all rubbush on T1
Press MENU key. Press Param. press PAGE, bring cursor to OP12, press
111111118 IMPUT
Power off/on
To clear tool data
Press MENU key
Press T-Data
Press 8th button from left
press CLEAR key
To clear "Tool set"
Press menu key
Press T-SET
Press 9th key from left
Press CLEAR key
To clear cutting conditions
Press MENU key
Press C-COND
Press 9th button from left
Press CLEAR key
To clear "Programme"
Press MENU
press PROG
press ALL ERASE
press INPUT
To clear parameters
press MENU key
press PARAM
press 8th button from left
press CLEAR key
press PAGE menu
press 8th key
press CLEAR key
To load all information
bring cursor to A7
press 16 then INPUT to set baud rate
bring cursor to OP2 and press
000000101 then INPUT (to set CMT available
Power off/on
If you have CMT or micro disk or Griffo with info on it, connect to machine.
Press MENU
press DATA IN OUT
press DATA IN
press 123456
press INPUT
the CMT will load all information
otherwise you will have to load it manually.
to load parameters OP1/16, there are 8 digits 0 or 1, if there are 2 "1" on line type 2 as 9th digit etc
Hello,
I'm having the same problem ... 4 years without electricity!
Is your mazak with Mazatrol T1 running back?
Yours sincerely
Frederik form belgium
do you EIA or mazatrol?
can help me with post processor?
- - - Updated - - -
does mazak have a way to set up a LIMIT so you will not over travel in Z minus? for example to avoid crashing into the chuck?
There are barrier settings on tool set page, but still cannot guarantee that you wont crash, long jaws boring tools etc. Check 1st off at low rapid rate.
