588,487 active members*
5,171 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Key for computer control cabinet lost 1990 KM3P - Pics added
Results 1 to 5 of 5
    Feb 2007
    592
    Unhappy Key for computer control cabinet lost 1990 KM3P - Pics added
    Last time I posted was in January, now its August.
    Work was keeping me tired up solid until recently, my hours have now been cut which means I actually have time for "home work".
    I got the machine moved into its final spot. Wired up the phase converter. Ran new conduits and power lines so I now have power at the magnetics side disconnect. I am eager to twist the switch - BUT I wanted to be sure all is Kosher in the PC side when I realised I AM LOCKED OUT.
    Not sure if there is a way to look up the key pin code based on S/N, or is there a generic key that can do the job - or do I just break out the angle grinder and make a mess of things.
    This realisation came about 6pm local time, so too late to call HURCO, and I'm not sure it would do any good, HURCO doesn't want anything to do with any machine with factory blue paint.
    Jun 2008
    1104
    Drill a tiny hole on the back of the cabinet, right near the edge and level with the lock. Push a little pin in the hole to shove the lock back into it's housing.
    Feb 2009
    6028
    BTDT
    I just drill a hole right through the lock (main off of coarse) and order new ones from mcmaster.
    Feb 2007
    592
    Quote Originally Posted by bloke View Post
    So does the reverse pressure on the lock release the lock?
    Oh wait, This is not like the safety interlock which uses a plunger style latch. This is a key lock that has an arm an a 90 degree throw.
    Attachment 196626Attachment 196628
    Feb 2007
    592
    OK - I got impatient and decided to drill the lock. This machine is in my own shop so there is no need to keep it locked up.
    So I do the deed, and sure enough Bloke was right. A 2mm hole and a 1/16" dia welding rod would have popped it right open. I swear I would have put my money on the table and bet that the lock was a rotating arm type. I been sticking my head into too many strange machines.
    Lock as viewed from the "hard to get to" side.
  1. Matsuura, lost computer and need to reconnect?
    By ts5089 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-20-2016, 05:43 PM
  2. 1990/92 Mighty Comet Mill Parameters/Mitsubishi control
    By kburns in forum Want To Buy...Need help!
    Last Post: 04-03-2013, 09:42 PM
  3. Found a great price on a computer cabinet!
    By blackhollowmfg in forum Waterjet General Topics
    Last Post: 01-31-2007, 12:53 AM
  4. Computer Cabinet
    By bearracecars in forum Waterjet General Topics
    Last Post: 12-21-2006, 08:01 AM
  5. New cabinet for computer and CNC -INPUT?
    By mlaws1172 in forum CNC Machine Related Electronics
    Last Post: 09-03-2006, 11:51 PM
