Find a deflection calculator online and start putting some numbers in. You will be amazed at the difference certain changes make.
If I was to start from scratch I would use large square extrusion for my uprights rather than plate. Unless you find cheap scrap plate, it'll often be cheaper to buy a length of extrusion than the large plate need for gantry sides. Have a look at the moment of inertia for various extrusions.
See cnc router parts or kronos designs for examples. I think the most frequent weak point in most diy designs is the gantry uprights, usually plate with minimal bracing. These can easily bend or if using round rail allow pivoting.
