588,434 active members*
5,505 visitors online*
IndustryArena Forum > CAM Software > MadCAM > 5 axis Y-B trunnion table
Results 1 to 19 of 19
    Mar 2006
    29
    How do I set up the graphics and post for a Y-B rotary trunnion table? The only option I see is X-A rotary. There must be a way to change the orientation both graphically and for a particular setup I need.
    Rhino 5 madcam extras
    www.yanvrno.com
    Think I found another post that can answer my questions. It helped but no cigar.
    I need both a new graphic representation of the setup and a step by step way to create the new orientation.
    Thanks for any help.
    where are the graphic files located. I just might have to make my own.
    Mar 2004
    1661
    This might lead you on the way;
    Open the help file and search for "Machine files" and "DLL". If you can't make it with the default machines and tweaks on the axis setup (like it says in the Machine files chapter) you must make a custom machine as in written in the DLL chapter.
    Hope that helps!
    /S
    Feb 2006
    183
    If you use the default trunion table machine, I think the easiest way is to just change the direction of the fourth axis.
    1) Select the trunnion table machine in madCAM.
    2) Go to advanced settings.
    3) Change the rotation axis 1 from (-1,0,0) to (0,1,0) or (0, -1,0) depending on the direction of rotation of the fourth axis.
    4) Save your machine in madCAM by clicking on the save button.
    If you are using stl-files for the machine parts simulation, you need to rotate them 90 degrees. You can draw your own machine parts in Rhino and save them as stl files. You can browse and select them from Advanced settings / Machine parts.
    /Joakim
    Mar 2006
    29
    Where would I find the dll file that would be right for my application?
    Or can I edit a dll source file and recompile to a file of my needs?
    I have to assume the simulation graphics are imbedded in the dll file.
    This shouldn't be that hard to get a handle on a simple orientation issue. :stickpoke
    I can change the rotation fine but I would also like to have the simulation icon refresh to the new file I created.
    Mar 2004
    1661
    Quote Originally Posted by Ya-Nvr-No View Post
    It's all in JOM's answer. You've got the rotation correct, right? Then model your machine parts as decsribed.
    What Simulation icon are you talking about? Actually I have no clue what you mean.If I guess, you mean that your simulation doesn't show your configured machine. Have you made the settings for your machine, saved them and then selected the machine as your default setup?
    Mar 2006
    29
    This is the icon I am referring too.
    Id like this to reflect the representation of the axis directions.
    Where are the images found so I can edit or create the new axis choice.
    Changing the
    "Axis_Mode" value
    0 ------ XYZ 3 axis
    1 ------ XYZA 4 axis X axis rotate
    2 ------ XYZAC Trunion Swing, Table Rotates
    3 ------ XYZAC Head Swings, Head Rotates
    4 ------ XYZBC Head Swings, Table Rotates
    5 ------ XYZAB Table Rotate, Head Swings
    www.yanvrno.com
    Thanks for your help.
    Apr 2003
    1357
    You want to know where to find the picture that is displayed with each machine type, so that you can change it to represent your machine? Is that correct? You have the machine configured correctly, but the picture misrepresents your set-up, right?
    That's a good question (if in fact, I am understanding correctly).
    Sorry, I don't have the answer. But if Joakim makes this possible, I too would be interested in changing the illustrations to match my machines. I have 9 different machines sharing 2 pictures.
    Dan
    Feb 2006
    183
    This is a good suggestion. I haven't thought about this, I've only made ​​it possible to change the 3D models for the simulator. In the next release, I will make it possible to also save images.
    Joakim
    Apr 2003
    1357
    Thanks Joakim.
    Dan
    Mar 2006
    29
    That is exactly what I am referring too!
    Thank You for understanding my post.
    Looking forward to the future version that will give me several more visual options that would reflect the actual setup.
    I would be very happy if I could link a graphic that I could create. So having a additional link choice for the graphic would be excellent. Just like we choose the Tool, Post or Machine, I would like to be able to choose the graphic. Having a separate folder with several bitmap selections. I could even have photos of the setups or machines.
    Thanks again for a great product.
    Mar 2004
    1661
    Ah, you meant that icon! Or, image...
    Yes, totally agree. Simple idea but good feature!
    Mar 2006
    29
    I have seen several version updates but this has never been addressed. Any idea when this might be implemented?
    Dec 2007
    83
    Re: 5 axis Y-B trunnion table
    Hi, Just chiming in to see if this is implemented yet. I just bought a Mira Mill and need to re-configure the Machine settings and would love to have visual reassurance that I've done it correctly
    dh
    Apr 2003
    1357
    This is a good reminder. I had forgotten about this too.
    Dan
    Please i need help , i am new in this field . i try to use STL file on MADCAM to create a 5 axis toolpath ( 5axis rotary head machine ) but i try all the ways and i had not get it . please try to help me step by step . thank you .
    Apr 2003
    1357
    Can you explain what you have tried so far? Can you post a screen shot of your part? More information is needed for a meaningful response.
    Dan
    Dear Joakim ,
    wish you a nice day , I sent you a gift and it return back to me through post office , i e-mail you but you had not reply . please contact me on [email protected] or [email protected]
    I have a problem setting 5 axis , the problem is that in post prossecor i add the length for my spindle mottor rotation center till the end of the spindle chuck , i do 2 G-code as attached files one using a spindle with long 40mm and the other one with 10mm , but if you check the 2 files they are exactly the same ( so the postproccesor had not add the spindle tool long to the distence of motor rotaion )
    https://drive.google.com/open?id=0B3...kY4VGl6VzE0QVE
    Thank you for your help.
    *TOOLPATH_OUTPUT*
    TRANSFORM
    *AXIS_OFFSET*
    169.5
    *TOOL_LENGHT_OFFSET*
    YES
    Apr 2003
    1357
    Hi Jeries,
    Not sure if this matters, but check out the correct spelling of that section:
    *TOOL_LENGTH_OFFSET* // Set Yes for using tool length from the saved cutters.
    thank you Dan ,
    Jeries
  1. Post for Haas Vf 2 with Trunnion Table
    By Mobbbl in forum Post Processors for MC
    Last Post: 01-25-2012, 12:32 AM
  2. DIY trunnion table? Anyone made one for 4th axis?
    By SlowRiderr in forum Haas Mills
    Last Post: 01-16-2012, 03:40 PM
  3. Trunnion table
    By Scottluther in forum Benchtop Machines
    Last Post: 02-27-2011, 11:57 PM
  4. Trunnion Table for Syil X4
    By CJCNC in forum Syil Products
    Last Post: 12-22-2010, 04:49 PM
  5. Trunnion Table for 5-axis
    By Zumba in forum Uncategorised MetalWorking Machines
    Last Post: 05-02-2006, 04:09 PM
