603,344 active members*
3,316 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > Omni tech CNC 1212 does this machine have Limit switches and Home switches.
    Mar 2013
    35
    Yes it looks like you have limits/home switches. My OMNI is wired the same way. It sounds like your Mach3 settings need a look at. I am more then happy to help you. Post a screen shot of your ports and pins input tab.
    John
    Sent from my iPad using Tapatalk - now Free
    Oct 2013
    12
    I was able to get everything worked out with the switches. I was told about the XML. file that came with the manufacturers configs. Only problem that I am having now is getting the auto tool zero working. I also connected the vacuum pump. When I press the green button on the control cabinet I hear a click at the vacuum and then nothing. Any hints to hook up or turn on?
    zach
  1. Home switches and Limit Switches
    By TheBulk in forum DIY CNC Router Table Machines
    Last Post: 03-12-2011, 12:08 PM
  2. Limit/home switches on converted machine
    By hobbybob1 in forum Mach Mill
    Last Post: 02-08-2011, 02:30 PM
  3. The relationship of limit switches to home switches.
    By MikeAber in forum CNC Machine Related Electronics
    Last Post: 11-04-2004, 08:28 PM
  4. Limit switches and home switches
    By viktorcnc in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-03-2004, 12:11 PM
  5. Home switches and limit switches.
    By ynneb in forum CNC Machine Related Electronics
    Last Post: 04-08-2004, 11:32 PM
