This is yet another thread about undocumented wiring for power supplies, BOBs, and stepper drivers. I have DM542 stepper drivers, a DB25-1502 BOB, a 36v power supply, and a 5v power supply. The power supplies can use either 220vac or 110vac. I'm planning on using 110vac initially. I've found enough info online to wire everything except what should be the simplest, the 110vac input. The power supplies have 3 input terminals: L, N, and Earth. The question is does the 110vac ground get connected to the Earth terminal on both power supplies? Should the Earth terminals on both power supplies (and ground on the BOB) be directly connected?
I'm also using shielded wire between the BOB and the steppers, where should the shield be connected?
