588,500 active members*
4,944 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Anyone have experience with pricing for low volume metal stamping companies?
Results 1 to 6 of 6
    Jan 2012
    19
    Simple, small, box type structures (been using a brake and it doesn't look quality) - nothing fancy in design. Anyone have any knowledge of what low production run companies charge (ball park figure) per unit, or how do they operate? Also, and suggestions on who to contact with inexpensive pricing for a startup company, would be appreciated. Thanks.
    Mar 2007
    100
    Maybe you could use a bud box at www.budind.com
    Sent from my iPad using Tapatalk
    Jan 2007
    1795
    regardless of quantities, a box likely 5x5 inches 2 inch height wil cost thoushands itself the cutting and another thoushands the folding tool..
    the dme housing what used for this not cheap at all.. plus the manufacturing cost for the tool..
    you might have to pay for in advance..
    cutting cost on this project (guessing you talk about a box with 4 side folded up)
    cutting with water or laser the unfolded parts.. mightbe trumatic..
    and mount on the break some super precise stops.. you can have closely or same result than from tools.. of course more cost per piece, and slower..
    those stamp tools are expensive, because they makes the massproduction.. a good tool makes 20-24 K parts daily.. so on the end a box will be as low as almost just the material price..
    but for this you have to invest a lot on front..
    Jan 2012
    19
    Thanks. After looking around, I actually might be able to use a cooking pan - they come in all sizes and shapes and materials. I would have to punch a hole in the bottom though for my project. I have a 20 ton press. Would fabbing up a 1/4 thick wall (maybe that thickness is too big?) round pipe, with an edge ground all the way around, to make it very sharp, and a connection piece for connecting the "punch" to the ram/press work for punching a hole in the bottom? If I have the bottom of the pan sitting on plate steel, and lower the fabbed punch onto the bottom of the pan, and engage the ram, would it cut through the material? Thoughts on this? Thanks!
    Feb 2009
    6028
    It would be quicker to use an arbor press with a modified Greenlee punch.
    Jan 2012
    19
    Yea, but the hole is going to be rectangular - approx. 4"x5"...
  1. NEED A QUOTE - Small Metal Stamping
    By ahk199 in forum North America RFQ's
    Last Post: 09-25-2014, 05:00 PM
  2. RFQ - cutting/stamping expanded metal
    By badger1 in forum RFQ (Request for Quote)
    Last Post: 09-25-2014, 04:22 PM
  3. Metal Stamping/Forming
    By drakke in forum MetalWork Discussion
    Last Post: 09-25-2014, 04:18 PM
  4. RFQ - Small Metal Stamping
    By ahk199 in forum RFQ (Request for Quote)
    Last Post: 02-10-2014, 05:33 PM
