587,311 active members*
3,512 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Cincinnati Milacron Sabre 1000, ALARM 44-43 Unused Channel Disconnect
Results 1 to 5 of 5
    Jul 2010
    5
    Hello,
    I am new with Cincinnati Milacron Sabre 1000, when I start the machine I get this alarm, "ALARM 44-43 Unused Channel Disconnect"
    Any advice will be helpful.
    Thank you.
    Sep 2010
    1765
    often telling you the DV5 axis input jumper plug for missing rotary table is not not plugged in.... or jumper plugs at outside of machine for the troyke table cables - jumpers there too.
    Apr 2004
    353
    On your pendant, select Setup, Rem Axis, and disable the 4th axis. This should solve the problem
    ok you should have a plug looking like a monitor plug but in silver and no wire coming out of it around somewhere (that does nt mean it has no wires in it) if you can t find it i could look it up for you to determin which pins are closed to each other . plug that in the last axis output in your servo card this should fix the problem.
    Jul 2010
    5
    Hello, I just unplug J5 cable, and plug "3-422-3514A CABLE - DVXL CONVENTIONAL SERVO PLUG", and the alarm is gone.
    Thank you.Attachment 212666
  1. Cincinnati Milacron Lancer 1000 manual needed
    By SQT18MS in forum Machinery Manuals / Brochures
    Last Post: 10-11-2012, 09:02 PM
  2. Cincinnati Milacron Arrow 1000 setting 3 yrs...
    By veggiedawg in forum Cincinnati CNC
    Last Post: 09-30-2011, 01:12 AM
  3. Cincinnati Milacron 5V-1000
    By wallyign in forum Uncategorised MetalWorking Machines
    Last Post: 09-11-2007, 01:41 AM
  4. Help on Cincinnati Sabre 1000
    By alexanderrt in forum Hard / High Speed Machining
    Last Post: 03-01-2006, 05:30 PM
