588,265 active members*
10,249 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Haas mill stops moving when using tool offset and cutter comp
Results 1 to 6 of 6
    Oct 2011
    31
    Angry Haas mill stops moving when using tool offset and cutter comp
    I wasn't sure how to title this. What happens is when I use cutter comp and apply a tool offset while machining a pocket the mill just stops moving when it reaches that portion of the code. The spindle is on, but the axis don't move at all. It will stay like that all day until I hit the reset button. If I remove the tool offset it doesn't do it.
    Machine is 1998 VF0E
    It is NOT the program. I have two other Haas mills and they can run the same programs without the issue.
    My dealer suspects it might be something in the processor. He has not looked at it yet.
    Anybody have a clue what it might be?
    Jul 2005
    12177
    Try increasing your tool comp lead in distance. I had an early MiniMill that did something similar when the lead in distance was nearly equal to the tool radius.
    Sep 2007
    100
    We have four VF2s with various versions of software on the controls.
    I have more problems with cutter comp on the newer versions of software.
    In some cases, programs that run on the older versions will not run on the newer.
    I sent an email to the factory and asked about this.
    The response was that the newer software fixed issues relating to cutter comp.
    MY response was that if I can run a tool and program on an older software version, but not the newer, then nothing was really "fixed".
    Oct 2011
    31
    I'm going to try updating the software. They can update for free as long as I stay with the same primary version.
    Sent from my iPad using Tapatalk HD
    Apr 2006
    3206
    Quote Originally Posted by Machining View Post
    ...with all due respect to the dealer.....
    We've had some interesting issues with newer controls using Wear comp.... input a value, and nothing changes... We're still trying to figure out what the real issue is so it can be addressed.
    For your problem, just to help sort out where the problem is, in normal cutter comp, make sure that your lead in when initiating the G41/G42 is greater than the radius, and ideally it's around 90deg to the machined edge so the control can calculate properly. I haven't had this problem so much on the Haas, and using wear comp I've gotten away with things that normally wouldn't fly. We have noticed though that different Haas controls seem to have different idiosyncrasies.
    I've had a few controls that required me to initiate the offset above the part, then move the spindle down to start the cut when doing pockets or in tight spaces.
    What CAD/CAM software are you using?
    John
    2007 HAAS TM-1P OneCNC XR5 Mill Pro. Shopbot PRT running Mach3 2010 Screen Set, Super PID and PMDX Electronics.Check out my Gallery on: http://[email protected]
  1. HAAS Visual Quick Code / CAM Cutter Comp Interference
    By wwholden in forum Haas Visual Quick Code
    Last Post: 03-29-2015, 01:52 PM
  2. Post for Haas with cutter comp?
    By mwestvang in forum Rhinocam
    Last Post: 04-30-2011, 05:21 PM
  3. Help Needed: Lathe live tool milling Cutter comp.
    By joseph10s in forum Hyundai Kia
    Last Post: 03-30-2011, 03:08 AM
  4. Cutter Comp in Haas post
    By helocat in forum Haas Mills
    Last Post: 06-21-2010, 12:39 PM
  5. X2 Slot mill and cutter comp. don't work?
    By foxsquirrel in forum Mastercam
    Last Post: 04-20-2008, 10:15 PM
