587,760 active members*
2,668 visitors online*
Results 1 to 8 of 8
    Sep 2005
    114
    inches per minute
    Hello, I have a simple question. I just got the mach3 and I do not have it hooked up to my machine yet cause it is not finished but I was playing with it loaded a g-code from bobcad into mach3 and was running it. And I noticed that it would rapid at 500ipm but I could not get it to go over 60ipm when it was cutting. What is going on here. Any simple answers for this.
    Scott :stickpoke
    35538
    1) did you set up the motor tuning?
    2) what does your g-code look like?
    Sep 2005
    114
    Gerry yes I setup the motor tuning to do 500ipm. I do not know how to upload a text file or I would let you see it. what would be the speed setting in the g-code file. And it actually is n-code I guess all n's no g's
    Attached Files Attached Files
    Sep 2005
    114
    It did upload the file. Great!
    Jun 2003
    2103
    planescott here is a screenshot of the first few lines of your code. Notice the F15 and F20? Those are feedrates set in the gocde. If you are machining at 60ipm you either have a f code using that as your speed or you have a feedrate overide somewhere.
    Mike
    Attached Thumbnails Attached Thumbnails iviewcapture_date_24_02_2006_time_13_36_43.jpg
    No greater love can a man have than this, that he give his life for a friend.
    Sep 2005
    114
    oh ok, Thanks Mike It must have been in the bobcad cause it does allow you to make all types of settings depth, roughing and such. It probably did put a speed somewhere. :idea:
    35538
    You can do a find and replace in Notepad, and change the F20's to whatever speed you want, or set up BoCAD to use the speed you want.
    Sep 2005
    114
    Thank you Gerry that was a very simple way to do it. :wee:
