587,997 active members*
1,927 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > How do I test the Master Control Relay on a Fanuc VCU need to fix error 401
Results 1 to 3 of 3
    vfsi Guest
    My situation:
    Fanuc 6M-B Control Mori Seiki 45/40 3 Axis Mill
    Velocity Control Unit A06b-6047-H003 PCB A20B-0008-0320/08C
    Start of problem: Powered up one day and received 401 servo error. Cycled power all was good. A few work days later the 401 servo error returned at power up. A power cycle added errors 411 and 421. Now every power up results in the 401, 411 and 421 errors.
    Upon startup:
    Bubble Read as it should then when the servos are powered up the 3 MCC relays kick in then after a few seconds they drop out.
    Control displays errors
    401 serov
    411 x-axis
    421 y-axis
    No errors on the drive LEDs. No errors on the spindle LEDs
    Drive Vcc RDY LED is lighted PRDY LED flashes on right before the MCC's drop out.
    Hydraulic pump reaches pressure, Lube pump activates.
    Incoming voltages 212.6 VAC, 212.6 VAC, 213.1 VAC
    Voltages to the drives 101.2 VAC and 175.6, 175.9, 175.9 VAC
    Drive voltage 22.78 VDC at CH15, 15.13 at CH16 VDC, -15.11 VDC at CH17
    Tables are not on the limits and have not been on the limits recently.
    After reading all the post about my issue, the possible causes could be bad MCC(s) or bad main board? How do I test either or both. Is the 3 phase AC voltage into the VCU's correct? I couldn't find any documentation on what it should be.
    Any other Ideas?
    Thanks for your help.
    Feb 2006
    58
    First check your servo drives for alarm LEDs. Also check your fuses. The other two errors will go away if you fix your 401 error.
    vfsi Guest
    I have tested all the fuses that I can find and they test good. I don't have any alarm LEDs lit on any of the three VCU's nor on the Spindle drive. So I do not know what to check next.
    Any other Ideas?
  1. fanuc control 10t machine error lamp on
    By Asfar in forum Fanuc
    Last Post: 01-13-2012, 06:14 AM
  2. Fanuc Oi-TC Control Memory Card Error
    By Brenda Cash in forum Fanuc
    Last Post: 06-29-2011, 10:03 PM
  3. Fanuc Pro 3 Control 16i Memory Card Error
    By bassboarder85 in forum Fanuc
    Last Post: 11-12-2010, 10:24 PM
  4. FANUC 10M RAM TEST ERROR
    By cncmori in forum Mori Seiki Mills
    Last Post: 02-09-2010, 11:01 PM
  5. Replies: 7
    Last Post: 10-26-2008, 08:51 PM
