587,787 active members*
6,392 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Heidenhain TNC155 keeps losing parameters
Results 1 to 3 of 3
    Jan 2008
    4
    Unhappy Heidenhain TNC155 keeps losing parameters
    Hi all.
    For no *obvious* reason, our Bridgeport 412 + Heidenhain TNC155 combination has suddenly taken to losing its parameters every time we power down.
    Buffer battery voltage looks fine, and I have tried both rechargables (NiMHs) and alkaline Duracells.
    I can upload a new parameter file using TNCremoNT, after which the machine starts up in English and will upload part programs. This is a faff, and crucuially loses Program 0 that contains all the tool offsets and turret data.
    The parameters disappear again on powerdown, leaving me with a German-speaking machine saying "Betriebsparametern geloescht" etc., next time I power up.
    Any thoughts on where I should look for troubleshooting? It's behaving as if the battery voltage is not getting to the motherboard.
    Thanks, Tim, Bolton, UK.
    Oct 2007
    179
    Try Machine Support Services Mike Coulton..experts on Heidenhain controllers!
    John
    May 2004
    402
    The back up batteries are diode isolated from the RAM board charging circuit, sounds like the diode has gone open circuit. As said give Mike Coltron a call, and when you do give him my regards,
    Andrew Mawson
    Andrew Mawson
    East Sussex, UK
    Nov 2022
    Re: Heidenhain TNC155 keeps losing parameters
    i have the same problem and i test the batary cell ..it is ok4.7v so please told me where i find the diode to chick up
    regards
  1. Looking for software for Heidenhain TNC155 B/TNC 155 Q
    By Altonjones in forum Bridgeport / Hardinge Mills
    Last Post: 11-16-2011, 07:32 AM
  2. 4th axis - Bridgeport 412 + Heidenhain TNC155
    By Fudge in forum Bridgeport / Hardinge Mills
    Last Post: 03-29-2011, 04:24 PM
  3. Problems starting up Heidenhain Tnc155
    By Oviksnc in forum CNC Machine Related Electronics
    Last Post: 12-18-2008, 10:54 PM
  4. Need help with a Heidenhain TNC155 Post!!!
    By Kim in forum Post Processors for MC
    Last Post: 11-09-2006, 09:31 AM
  5. Still struggling with the Heidenhain TNC155
    By plane magic in forum Bridgeport / Hardinge Mills
    Last Post: 10-26-2006, 11:07 AM
