587,776 active members*
2,708 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Cutting Depth Issues with 2-Sided machining on MeshCAM
Results 1 to 8 of 8
    Jan 2014
    4
    Hello,
    Need some insight.
    Setting up two sided machining for a part.
    My issue is around the cutting depths. Part is centred in stock. Stock is square and square to table.
    Cutting the "top" file is successful. When I flip the part and run the Gcode it cuts too deep and removes material it shouldn't.
    My cutting depth is currently set to the middle of the part but on the "bottom" tool path the geometry is beyond the mid-point of the part.
    When running this code it does not cut the geometry i need it to cut.
    When I switch and set the cutting depth to the bottom of the stock and run the "bottom" code, an extra .125" of material is removed. Almost like the centre line of the geometry is overlapping somehow.
    I've attached the files I think someone might need to help me out.
    Sam
    Sep 2012
    1195
    Can you post the .mcf file? It's really hard to say without seeing the geometry and the setup.
    35538
    Yeah, you really need to post the model and job files for us to really know what's going on.
    Jan 2014
    4
    Hello Gentlemen,
    Thanks for the reply. As requested, i've attached the .mc files so you can see the set-up.
    Thanks,
    Sam
    35538
    All you attached is the same g-code again.
    Jan 2014
    4
    apologies Gerry,
    Very green as you can tell and very stumped.
    Which file is it you are looking for?
    I'm taking an STL file created on Rhino, importing to MeshCAM and creating the Gcode and then opening in Mach3.
    I've attached the STL
    Sam
    Sep 2012
    1195
    We'll also need the .mcf file, which is what you can save other than G-code out of Meshcam. This file will have all of your setup parameters for Meshcam in it, otherwise we don't have any way of telling you what you may be doing wrong. Go to "File -> Save Job" with the file open and set up as you have it, then post the file that results.
    Jan 2014
    4
    Thanks for the directions
    Attached is the MCF file
    sam
    Attached Files Attached Files
  1. Independent Cut depth two sided
    By chrisbryanolsen in forum Uncategorised CAM Discussion
    Last Post: 11-28-2014, 01:15 PM
  2. Meshcam... Stock size and Z Depth
    By dudz in forum Uncategorised CAM Discussion
    Last Post: 08-25-2013, 04:22 PM
  3. MeshCAM 4 Build, 2 sided machining
    By ViperTX in forum Uncategorised CAM Discussion
    Last Post: 10-09-2010, 09:37 PM
  4. Cutting depth issues
    By NylonAdmiral in forum Mastercam
    Last Post: 10-14-2009, 04:07 AM
  5. Can MeshCAM do 4 or more sided milling?
    By digits in forum Uncategorised CAM Discussion
    Last Post: 04-03-2008, 11:14 PM
