588,268 active members*
10,102 visitors online*
Page 1 of 2 12
Results 1 to 20 of 21
    Nov 2013
    143
    G0704 Spindle Lock
    Hey guys,
    I know that I don't post here very often and most people don't know who I am or what my company is all about, but that's OK. If you're interested in finding out more about ProtoSimTech, you can watch the videos on our YouTube channel for more info.
    That said, we were waiting on some tools to arrive and needed something to do, so we decided to tackle a little side project. We had a 4" diameter round bar lying around the shop and figured that that would be a perfect piece to build a spindle lock for our G0704.
    This is just our little version. I know there are several other versions out there and you can even purchase one from LMS for about $50. We decided it was more cost-effective to make our own. This is a variation of a spindle lock that we saw right here on the CNC forums (my apologies for not knowing which thread it was).
    Here's a short video about how we made ours.
    Chris
    You got the idea from kd4gij 12 days ago in my thread, you commented about it.
    http://www.cnczone.com/forums/bencht...ml#post1410018
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    Nov 2013
    143
    Quote Originally Posted by hoss2006 View Post
    Hoss
    Haha, you're absolutely correct!
    My apologies for not giving credit where credit is due. Thanks for correcting me, Hoss!
    No worries, I remembered you saying something about that hunk of aluminum and then remembered your post.
    Nice job by the way.
    Hoss
    Nov 2013
    143
    Hoss
    Thanks, Hoss =)
    Dec 2013
    158
    What is the purpose of this? Sorry still a bit of a noob with this stuff.
    Nov 2013
    143
    Quote Originally Posted by rs4race View Post
    You can lock the spindle in place so that changing tools is a lot easier. Little Machine Shop sells these things for about $50. Grizzly sells the same one for about $90.
    You can watch the video, and at the end I explain how it functions. I hope I explained it well enough. If not, I'll see if I can write out a tutorial on how it works.
    Feb 2011
    110
    Nice job
    G0704, Craftsman 101.07403.4x6
    Nov 2013
    143
    Quote Originally Posted by kd4gij View Post
    Nice job
    Thanks for giving me the inspiration
    Jun 2011
    695
    Nice work!
    Now get that CNC conversion going!! :banana:
    Hoss is the 704 master on here.
    Hurco KMB1 Build
    Wholesale Tool 3in1 conversion
    C-Constant
    N-Nonworking
    C-Contraption
    Nov 2013
    143
    Quote Originally Posted by FannBlade View Post
    Nice work!
    Thanks, FannBlade!
    The CNC conversion is probably not going to happen anytime soon, I'm afraid. As soon as we start making a profit, that might be something to invest in. We are going to get a power feed for the X-axis, though. That should make life a bit easier.
    1943
    Good job, but I would put a light spring or something under that bolt to prevent it from working inward due to vibration.
    Nov 2013
    143
    Quote Originally Posted by 109jb View Post
    Good suggestion. I'll keep that in mind.
    Feb 2011
    110
    I have the X axes power feed on mine. Don't no howe I got along with out it. Also Have Igaging scales on it.
    Nov 2013
    143
    One question I need to ask is, how heavy is that thing? Is there any deflection in the table with it installed? I would hope that deflection would be minimum, but with heavy things on the ends of the table like that, you never know. Just curious.
    Feb 2011
    110
    I am not shure of the weight but I have no deflection. It sits flush with the top of the table. I got mine from lathemasters for $40.00 cheaper but I don't see it on there site enymore.
    Feb 2011
    110
    Next I am looking to build a power feed to raise and lower the head.Cranking it is getting old.
    Nov 2013
    143
    Do you happen to have a cordless drill lying around? If you don't care about precision, you can just use that to lower and raise it. I have a couple of DeWalt cordless drills with a socket attachment that I use to move the table and head assembly when I'm feeling lazy. Just a thought. Again, this shouldn't be used for anything requiring accuracy.
    Feb 2011
    110
    I use the quill fine feed for for milling. Use the quil for drilling. Looking for a permanit fix for raizing and lowering the head. looking for a cheap gear motor with verible speed. Not shure howmuch touque I need or weather to mount to the handle or drictley to the lead screw.
    Nov 2013
    39
    Re: G0704 Spindle Lock
    Nice project. I like the way the spindle nose isn't covered up. I like to turn that by hand
    while fiddling with tools.
    Anyway, purpose of my reply... Instead of milling away that vast amount of material that
    took four hours, you could use a saw to rough it out.
    -Bill
Page 1 of 2 12
  1. Spindle Lock code???
    By bolduc04253 in forum Daewoo/Doosan
    Last Post: 05-09-2011, 05:15 PM
  2. Spindle wont Lock
    By nickmill13 in forum Uncategorised MetalWorking Machines
    Last Post: 07-15-2010, 12:57 AM
  3. Spindle lock
    By Larry Myers in forum Sharp CNC
    Last Post: 06-16-2010, 04:04 AM
  4. Spindle Lock for SX3
    By Old Megawatts in forum Syil Products
    Last Post: 05-01-2007, 11:19 PM
  5. spindle lock question
    By Scott-M in forum MetalWork Discussion
    Last Post: 12-01-2004, 02:18 AM
